1981 Nose/hood alignment HELP
Old Apr 8, 2016 | 09:45 AM
nix1981's Avatar
nix1981
Default 1981 Nose/hood alignment HELP
I've got a question for the group...
My 81 hood appears as if the middle (where it meets the nose) is 'diving' down. I believe the nose piece is actually lifted in center, which is giving this appearance of the gap etc. As if the front is being pinched and the center is coming up... I know there is a rod that connects the nose to the bottom part of the radiator support for support. I also have noticed that there seems to bee some sealant that helps hold everything down accross a support - that's deteriorated for the most part. Even if that were the only thing holding that down, it takes most of my body weight at 200lbs to get it flush with that support. No 'glue' is going to hold that down. My only thought is that the nose support rod can be adjusted some how to allow the nose in the middle to come down. There is a small 7/16" nut down by the radiator support then a rubber mount up top. HOW DO I FIX THIS???
Old Apr 17, 2016 | 02:00 AM
pdx-vette's Avatar
pdx-vette
Default Good question.
Old Apr 17, 2016 | 08:03 AM
4SPDL81's Avatar
4SPDL81
St. Jude Donor '16
The fiberglass has disbonded from the structure below...I used Lord Fusor 320/322 epoxy adhesive to effect a repair.... I did this repair about 7 years ago on my '81 and it is still holding today...(I used clamps and caul plates to put everything in position while the glue set up)...Good Luck!
Old Apr 17, 2016 | 07:02 PM
DUB's Avatar
DUB
I have repaired this problem numerous times.
nix1981.....basically where do you live...because you have not filled out your 'public profile'...so I (we) would at least know what state you live in....because if the car is SUPER COLD ...the panel is going to react differently than if you live in the deep south where it is hot now.
IF the panel and support beam is PROPERLY prepped...the adhesive will hold it....BUT...that is also depending if this car has been whacked in the front in a previous accident.
Some people will pump stuff in the gap and clamp it and let it go. Their choice...and '4SPDL81'...I am NOT implying that is what you did.
I myself ...because I do Corvette repair...would HAVE TO remove the support beam and headlight assemblies and bond it back in that way....because I HAVE to warranty my work and I do not have time to do things twice.
DUB
Old Apr 17, 2016 | 09:06 PM
nix1981's Avatar
nix1981
Thanks for the response guys! Im in northern VA/DC area.
Old Apr 18, 2016 | 06:34 PM
DUB's Avatar
DUB
AS mentioned a 'do-able' repair. If you plan on doing this yourself...ask for help if you feel you need it.
DUB
Old Oct 16, 2016 | 08:38 PM
nix1981's Avatar
nix1981
Revisiting this thread - 1) does the bumper extension that bolts to the frame have any adjustment for bring the nose up or down??? I read on old post (circa '06) that this was done.
2) Also, was wondering of a good quality adhesive that i can/should use for re-bonding the fiberglass back to the support one i get it where it needs to be. Preferably something in a tube??? What I've found is what's mentioned above Lord Fusor 320/322 (which does not seem to be readily available, ebay, amazon, etc.), Lord Fusor 127EZ (which seems to be for plastic, but people reference it), and 3M 8115. Thoughts on any of these?
To 1981 Nose/hood alignment HELP
