1972 fuel pump codes
Old Jun 2, 2016 | 10:07 AM
pep49's Avatar
pep49
Default 1972 fuel pump codes
I have what I believe to be the original AC fuel pump that I took of my 1972 small block. It is no. 40769 which the NCRS Technical Manual says is correct. Anyone know what the numbers that come first are? Date code?(029R 40769). Just curious.
Old Jun 2, 2016 | 10:33 AM
Alan 71's Avatar
Alan 71
Hi P,
I believe information about those digits and letter is still being gathered, but many folks think it may be a Julian date (3 digits) and a letter for the year.
When was your car built?
Regards,
Alan
This is on a car built in mid-January 1971.
So PERHAPS the 357th day of 1970?
Old Jun 2, 2016 | 11:20 AM
pep49's Avatar
pep49
Originally Posted by Alan 71
Hi P,
Regards,
Alan
Alan
Thanks for the reply. My car was built 13 Jan 1972.
Phil
Old Jun 2, 2016 | 12:33 PM
Alan 71's Avatar
Alan 71
Hi Phil,
That's just about 1 year after mine. My trim tag indicates the 14th, so I think it came off the line the 15th or 16th.
I don't know enough to respond in any meaningful way about your 'date'.
If its a Julian date I'd expect the digits to be lower than 13 (earlier in January) or much higher, (later in 1971).
The fuel pump went on the engine in ST.LOUIS so it's possible it could be quite close to the car's build date, but certainly not after it.
So like I said????
Regards,
Alan
Old Jun 2, 2016 | 01:04 PM
pep49's Avatar
pep49
Hi Phil,
So like I said????
Regards,
Alan
Thanks Alan
Your knowledge about our "toys" and willingness to share it with other forum members is certainly appreciated.
Phil
To 1972 fuel pump codes
