New rally wheels
Old Jun 16, 2016 | 10:07 PM
RizVet's Avatar
RizVet
Default New rally wheels
Just bought new 15x8 Rallye wheels from Zip Corvette. They came powder coated silver. Do they need to be painted? They look great as is. I know the perfect silver color can be had via spraying them but I believe it's overkill. Thoughts?
Old Jun 17, 2016 | 06:25 AM
530planeman's Avatar
530planeman
If they are powder coated you will need to sand blast off coating in order to paint them
Wes
Old Jun 17, 2016 | 06:52 AM
Shovels and Vettes's Avatar
Shovels and Vettes
Powdercoating is just paint applied in a different manner than a spray gun we are all used to. There is no reason to blast it off if you want to topcoat it with silver enamel. I am not even sure lacquer would really hurt it, but you would have to experiment. Otherwise, if the silver powdercoating looks good, why bother unless you are trying to win NCRS awards.
Old Jun 17, 2016 | 07:07 AM
530planeman
FYI This is a powder coated wheel good luck trying to get paint to stick as coating is baked on
Old Jun 17, 2016 | 07:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Do they need to be painted? They look great as is...
That's up to you. If you like what you have, no need to paint.
Old Jun 17, 2016 | 08:50 AM
bj1k's Avatar
bj1k
Why would you paint them, they are already painted with the toughest paint for holding up to rock chips ? That was the idea of them powder coating them .
Old Jun 17, 2016 | 09:05 AM
Jeff_Keryk's Avatar
Jeff_Keryk
I guess you know Argent Silver is the original Rally Wheel color.
Old Jun 17, 2016 | 10:03 AM
Alan 71's Avatar
Alan 71
Hi R,
There's a thread on this same page as your post in which Rowdy Rat explains the difference in color of the rally wheel silver and 'argent' paint and the likely time frame for the 2 color's use.
You might want to check that out and see if it matters to you.
Considering the amount of the wheel that is exposed I think I'd do nothing to them.
Regards,
Alan
Old Jun 17, 2016 | 11:50 AM
redcruz1120's Avatar
redcruz1120
St. Jude Donor '09
Old Jun 17, 2016 | 06:07 PM
Shovels and Vettes
Default Paint
Has nothing to do with paint adhesion. You could probably scotch brite it to give the surface some tooth, but you blasting the wheels to remove such a good product is going backwards.
Old Jun 17, 2016 | 06:29 PM
530planeman
Hey
Just trying to advise you .You don't just scotch brite and have powder coating take on paint Powder coating is baked on in an oven and even applying powder coat over old powder coat doesn't work .Go to a powder coating company and they will advise you that the process is meant to be a process to stay.Personaly I would leave the wheels as they are
Wes
Old Jun 17, 2016 | 07:46 PM
The13Bats's Avatar
The13Bats
Sometimes powder coat can have good cohesion but poor adhesion, you know a hard shell that remains (for a while) unbroken but does not stick to the metal underneath, in a way like POR can do but if water gets under it off it comes in sheets,
People do scuff/prep and paint over powder coating with satisfactory results but yeah, in this case the only reason you would wanna do that is some purist or modding idea to change the color the wheels were powder coated because in this case it's better than paint.
Old Jun 18, 2016 | 12:56 AM
Giddy-up Go's Avatar
Giddy-up Go
I'd leave it the way it is. If it ain't broke, don't go breaking it.
Old Jun 18, 2016 | 03:15 AM
LT1M21Vette's Avatar
LT1M21Vette
Hey
Wes
Yup, and good luck media blasting powder coated wheels.
Old Jun 18, 2016 | 09:19 AM
bj1k's Avatar
bj1k
I've had customers come into the shop with frames etc. and want additional brackets welded on to the frame after powder coating and that stuff is so hard that it is hard to grind down through it with a rock grinder. So media blasting , I don't think so!
Old Jun 18, 2016 | 10:17 AM
croaker's Avatar
croaker
Go with Alan as how much of the Silver really shows anyway. I couldn't find the correct silver without mail order coming into play.
Old Jun 18, 2016 | 10:34 AM
530planeman
Glad to see someone that knows what they are talking about .My wheels came with a 5 year guarantee from chipping and peeling .
Wes
To New rally wheels
