C3 wiring
Old Jun 21, 2016 | 01:01 PM
clayshooter's Avatar
clayshooter
Cruising
Default C3 wiring
I am in the process of altering the lights on my Stingray to meet UK regs and have found a pair of loose wires at the rear end behind the number plate coming out of the loom with the number plate light wires. One is red the other black. Can anyone tell me what they would be intended to be connected too, also where to find them in the cockpit.
Many thanks in anticipation. Mike
Old Jun 21, 2016 | 01:06 PM
Mark Riles's Avatar
Mark Riles
We'll probably be able to help better if we know the year. They changed a few times between '68 and '82.
Old Jun 21, 2016 | 01:23 PM
clayshooter
Cruising
Hi Mark, it is a 1973 model
Old Jun 21, 2016 | 02:51 PM
Alan 71's Avatar
Alan 71
Hi c,
Does your alarm system work? What are the connectors like?
Perhaps the 2 wires are for the alarm?
Check to see if the switch in the center of the rear panel is hooked up.
Regards,
Alan
Old Jun 21, 2016 | 03:12 PM
CA-Legal-Vette's Avatar
CA-Legal-Vette
That was an amusing little exercise. I looked under my 73 only to find a bunch of loose wires, all of which are black with grime.
A quick check of my Doc Rebuild wiring diagram and I'm pretty sure that Alan is right. They're probably the connections to the key that arms the alarm system. Let me know by PM if you'd like me to scan and email the schematic.
Old Jun 21, 2016 | 04:25 PM
clayshooter
Cruising
There is no alarm fitted and no switch in the rear panel. I`d love a proper wiring schematic, I`ve found a few but none shows these wires.
Many thanks for your inputs. Cheers. Mike
Old Jun 21, 2016 | 04:46 PM
Tooch1's Avatar
Tooch1
Hello,
Still not sure of the year of your car? But 73 was mentioned above. Here is a photo of the wiring diagram in the rear area of a 73. Sorry for the shadow in the pic, but you can make out all the wire colors on it.
Hope this helps,
Jim
Old Jun 22, 2016 | 09:30 AM
clayshooter
Cruising
Thanks everyone, after a good look behind the number plate area in the day light and a better torch I have found the alarm horn and traced a wire to it so mystery solved. Mike
Old Jun 22, 2016 | 12:27 PM
clayshooter
Cruising
Originally Posted by Tooch1
Hello,
Hope this helps,
Jim
Hi Jim, thanks for that, I am pretty sure the wires were meant for the alarm which is no longer hooked up but I did find the old horn under the left wing. Is there any chance you have a front wiring diagram to show where the wires start that you could email me.
Cheers Mike
To C3 wiring
