Where Does This Part Belong?
Old Oct 13, 2016 | 05:35 PM
69L46vert's Avatar
69L46vert
Default Where Does This Part Belong?
1969 L46 no AC
Installing radiator and fender skirt seals and am at a loss as to where these seals/baffles go. .
In the photo the part at the bottom is an original from this car. The two shouldering the label are the new ones that came in the package from the good Dr. .I've scoured the AIM to no avail. Evidence of two 1/2 inch staples that held the original but to where? Thanks for any help, Rick
Old Oct 13, 2016 | 05:43 PM
bazza77's Avatar
bazza77
it shows you in the picture , just to the left (toward the front of the car ) of the top A arm unit ,it staples onto the bottom of the wheel well and is designed to seal the gap between the wheel well and the top of the frame in that area
Old Oct 13, 2016 | 05:48 PM
Alan 71's Avatar
Alan 71
Hi 69,
There was one flap stapled to the bottom forward edge of the wheel-well apron to close the gap between the apron and frame.
The flap was on the engine compartment side of the apron, and the staples were driven from that side too.
Regards,
Alan
Left wheelwell apron
Right engine compartment side apron.
Old Oct 13, 2016 | 06:15 PM
69L46vert's Avatar
69L46vert
Originally Posted by Alan 71
Hi 69,
Regards,
Alan
I owe you a cup of coffee Alan. Thank You so much
Old Oct 13, 2016 | 06:29 PM
69L46vert's Avatar
69L46vert
Thanks Bazza. I see now. The illustration looked like it showed the extruded material included in the kit rather than the flap/baffle type. I'll look for the staple holes tomorrow. This part of the job is a bit tedious but still fun. Thanks, Rick
Old Oct 13, 2016 | 06:41 PM
Alan 71's Avatar
Alan 71
Hi 69,
I've seen that extruded piece in the Dr's drawing too. I guess perhaps it was used at some point?
Extruded pieces that are similar to the seals on the 2 splash shields WERE used at the joint of the top of the apron to the underside of the hood surround.
It's all in fun!
Regards,
Alan
Old Oct 13, 2016 | 07:34 PM
bazza77's Avatar
bazza77
Understandable ,if they aren't already old pieces on the car finding the staple holes as a clue is almost impossible , especially down there were its hard to see did you get new staples in the pack ? I recall they sell black coloured stainless ones for NCRS and wont rust up . If your at the end of a resto , yes its the fun time when small additions get you noticeably closer to finish.
Old Oct 14, 2016 | 07:53 AM
Alan 71's Avatar
Alan 71
Hi b77,
Sorry, but if staples were used, and they typically were, the staple holes are very obvious because of the size and shape of the holes they made in the fiberglass apron.
You can easily see them in the first picture I posted.
It's a quite straight forward job to use the same holes to install the new staples for the seals.
Also, I'm not familiar with the the NCRS requiring black staples… where is that information given?
Regards,
Alan
Old Oct 14, 2016 | 08:28 AM
69L46vert's Avatar
69L46vert
I've been using plain steel wire to make staples. It came with the kit. Using a pin drill to go through the new material and using the original holes in the fiberglass (and sheetmetal in the case of the lower splash shields).
The AIM clearly shows the extruded material (same as the upper skirt seals) in the lower position against the frame but the evidence here shows that was not how it was actually done. It was in reality just like Alan's pictures using a flat "flap" rather than the extruded material. And in this case, two staples rather than the four that the AIM shows in that area. The extruded material would have needed all four staples but the "flap" would seem to be secure with just the two.
Old Oct 14, 2016 | 08:34 AM
Alan 71's Avatar
Alan 71
Hi 69,
You're right, 2 staples would be sufficient.
I used the holes in the apron as a guide to where and how many staples were originally used.
Regards,
Alan
What I found is that the extruded seal really couldn't be used because the gap between the frame and apron was to high for it to actually make a seal.
Old Oct 14, 2016 | 08:44 AM
69L46vert's Avatar
69L46vert
Hi 69,
Regards,
Alan
I saw that too Alan. The extruded material would not be wide enough to fill the gap. Hence the flap.
I really was puzzling over this yesterday. Since I had the old piece, I knew it had to go somewhere. I looked and looked and just couldn't find the spot. I just got the heat going in the garage. Going back out today to get some more of this sealing business taken care of. Thanks for your help.
Old Oct 14, 2016 | 10:14 AM
bazza77's Avatar
bazza77
Hi b77,
Regards,
Alan
we can see them yes , but for someone who, s car no longer has the seals and maybe the engine bay isnt clean and has road grime , dust mud etc (area is overcoated in re-sale black !)in there then finding old holes may not be so easy, especially when standing looking down into the area. As for the ncrs requirement, I did read it in a sales catalogue about coloured wire (staple) to look the part , I have never read any ncrs guideline about staples but I, d say the aftermarket parts supplier was putting their spin on it to .
Old Oct 14, 2016 | 12:10 PM
revitup's Avatar
revitup
Hi 69,
Regards,
Alan
I never even realized that seal was there until this thread. I even replaced the big control arm seal next to it and didn't notice. Looking at some pics I took when I rebuilt the front end, found a photo of the area in my unaltered (in that area) '77 that seems to show three staples.
To Where Does This Part Belong?
