Real Documentation and Numbers Matching
Old Mar 30, 2017 | 12:29 PM
  #61
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
Might there be a real paper copy of the build sheet somewhere else in the car?
Originally Posted by Alan 71
Hi c,
I believe the sheet (s) that ended up being glued to the tank were part of a 7 page 'Corvette Order' form.
I'm unsure if carbon paper was used between each sheet or if the paper was impregnated with carbon to make the copies.
It's some of those additional copies that are occasionally found elsewhere on some cars.
Regards,
Alan
Old Mar 30, 2017 | 12:44 PM
  #62
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by crawfish333
...Might there be a real paper copy of the build sheet somewhere else in the car?...
Maybe, but there are no guarantees. Owners have reported finding copies of the build sheet behind the speedo/tach, tucked in the wiring behind the center cluster, behind either kick panel, tucked in the springs under a seat, and beneath the carpet in the rear storage area. Later cars (78 or so) have had copies folded and tucked between the rear spring and spring mount.
Old May 22, 2017 | 03:44 PM
  #63
dustin zosky's Avatar
dustin zosky
Here is the original documents from my 69 that I have, the car is for sale also if interested. Thanks Dustin
Old May 22, 2017 | 04:03 PM
  #64
dustin zosky
Here is the POP for the car, all original stamps
Old May 22, 2017 | 11:16 PM
  #65
KingRat's Avatar
KingRat
Default It does happen.
Yes!... I took the carpet out of my '72 LT-1 and found this...
Old May 22, 2017 | 11:25 PM
  #66
dmaxx3500's Avatar
dmaxx3500
Originally Posted by Chevrolet Corvette
Does anybody want to take a guess as to what percentage of 1969 big block cars have their original engines and genuine documentation?.
mine does
Old May 22, 2017 | 11:31 PM
  #67
KingRat's Avatar
KingRat
Both of my '69s do.
Old May 23, 2017 | 04:58 AM
  #68
dustin zosky
My car did not have the original carpet in it so, I never seen that.
