Hi PMR,
The upper part of the a-pillar soft trim often gets beaten up/torn by the front roof panel latch and the corner locating pin on the roof panel.
I'm not sure if anyone is recovering them or not.
The reproductions are good, but not great, (as is the case with most interior soft trim parts.
Maybe a photo of the condition of yours?
Regards,
Alan
Most of the larger vendors carry the pieces.
For instance…Paragon Corvette Reproductions….. #7472rh. & #7473 lh.
Hi pmr,
I believe Willcox has interior soft trim on sale quite recently.
Perhaps you'd want to talk to them and see if a sale is coming up…. maybe same a few $.
Regards,
Alan
If you just have a 'split' in the vinyl covering, you may be able to repair it. Mix up some 2-part JB Weld epoxy; use a toothpick to insert a good amount of the epoxy into the split ON BOTH SIDES; put some waxed paper over the repair & then duct tape to hold the repair down to its original position. Let cure for a couple of days. Remove tape/paper, clean with light wipe of solvent, then recolor with vinyl dye mixed to your interior color or to match your interior.
Less expensive than buying repops; and you still have the original parts.
Thanks good suggestion, the interior is all original, seats, carpets, dash all fine.
The door panels have cracks, and the a-pillar on right side is missing a piece of the silver vinyl exposing the foam.
Ahh... Getting the surface to have the original texture--that's the 'ticket'. Such a thing is "do-able". But, you need to get some silicone potting material which can be pour/cast over a 'good' area of surface so that it will create the reverse image of the surface.
With that in hand, you can make your repair with Bondo, Shoe-Goo, whatever, put some kind of parting material on the surface mold you made, then press that over the repair material to recreate the surface texture. It ain't easy...but it can be done. Is it undetectable to a trained eye? No. Will normal people see it? Not if they are not looking right at it.
If you can approximate the original surface pretty well and the repair area is not a sizable percentage of the entire part, a good recolor of the part will hide any decent repair job. Just sayin'......
P.S. I'm partial to the epoxy type repair products as they don't require 'air' to cure them. And that helps if you are also trying to recreate the surface graining on a repair.
Hi pmr.
You might check out Creative colors international. Google wecanfixthat.com It looks like there are several shops in NC. There is one close to me that I've talked with about a small repair on my 91 and a cracked dash on my pickup. I haven't seen their work yet but it looks good in their video.
Bob
