Aluminum body mounts?
Old Jan 27, 2017 | 10:10 PM
Gold Dragon's Avatar
Gold Dragon
Default Aluminum body mounts?
Received my body mount kit yesterday for the 69. Guess I was surprised they are aluminum. Was thinking rubber was involved. Thought the corroded green chunks that came out were petrified rubber. I am sure members who have done this before find this post silly. Seems like I have seen newer C-3s with rubber bushings instead. Anyone know why GM used aluminum mounts on the older vettes.?
Old Jan 27, 2017 | 11:11 PM
gbvette62's Avatar
gbvette62
68-72 Corvettes used the solid aluminum body mounts. When they went to radial tires in 73, the switched to the rubber mounts, to offset the harsher ride of the radials. Some owners have replaced their solid mounts, with the 73-82 rubber ones.
Old Jan 28, 2017 | 08:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Gold Dragon
...Anyone know why GM used aluminum mounts on the older vettes?...
Who can say what was involved in decision making nearly fifty years ago?
Old Jan 28, 2017 | 10:21 AM
bj1k's Avatar
bj1k
Even though my 72 came from the factory with aluminum spacers I changed to the rubber but I will say that it requires a couple alterations because they are a little thicker and it changes the angle of the steering column where it meets the rag joint . You will have to lower the bottom end of the steering column to match the rag joint and that requires enlarging the fiberglass hole under the bottom of the steering column. Just a slight alteration and it doesn't change the looks of anything.
Old Jan 28, 2017 | 10:44 AM
7T1vette's Avatar
7T1vette
Solid spacers would reduce a bit of body roll when 'working' the car.
Rubber spacers would make the ride more pleasant. BUT, you would need to research the suppliers of those synthetic rubber parts to have confidence in their quality. Many vendors sell poor quality 'junk rubber' cushions, and you do NOT want them because they will disintegrate over time. Good quality rubbers will last another 40 years.
Choose wisely!
Old Jan 28, 2017 | 10:46 AM
The13Bats's Avatar
The13Bats
I had no clue radials ride harsher than bias plys...new tech for me there,
My 69 had at some point the aluminum mounts changed to rubber i knew that if i buy 73 up rubber mounts they are thicker i heard of special rubber mounts that are correct thickness for pre 73 but i couldnt find them i did find poly mounts the correct thickness for pre 73 and i used them...they will likely outlast me but in hindsite i wish i had ran aluminum mounts just because.
I would guess and just my guessing the factory went to rubber to help with noise and vibrations
Old Jan 28, 2017 | 10:40 PM
Gold Dragon
Thanks to all the heavy hitters who have posted on this topic. Although polyurethane bushings do sound like a good upgrade, thinking I will stick with the oem mounts. Nearly all the old Chevrolet's I have driven roll and lean in the corners, and they are all rubber mounted. Seems like a good reason to use aluminum. I am looking for the full on Corvette experience. Not going to be beating on this car when finished, but I will certainly be using it.
Old Jan 28, 2017 | 11:11 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
The local rubber products supply house made a set of spacers for me.....it took about an hour. They used conveyor belt material which has impregnated woven nylon cloth at 1/8" thickness intervals....Very Tough stuff.
No "offset-sqoosh".....no drastic compressing when torqued down...and I doubt any body movement.......$20 for the set...I added 1/8" thick stainless flat washers where needed to adjust door gaps, etc.
Old Jan 28, 2017 | 11:38 PM
NAVY08's Avatar
NAVY08
St. Jude Donor '06-'07
Thanks for asking! I had the same question myself!
Old Jan 29, 2017 | 01:10 PM
cv67's Avatar
cv67
St. Jude Donor '05
you should start selling em
Used repop rubbers on my abody could tell they wont be around long.
How hard is it to make decent rubber come on....
Old Jan 29, 2017 | 01:20 PM
Alan 71's Avatar
Alan 71
Hi,
"Nearly all the old Chevrolet's I have driven roll and lean in the corners, and they are all rubber mounted."
Wait a minute?????
The body mounts don't have anything to do with a car leaning and rolling in corners… that a suspension/tire issue.
The type of body mounts used is felt in the seat of your pants by your boney butt and kidneys when you drive over rough roads.
Regards,
Alan
Old Jan 29, 2017 | 02:08 PM
rajin cajin's Avatar
rajin cajin
I agree. My original bushings are in good shape believe it or not. I've rebuilt the entire rear-end to include all new bushings and shocks. That being said, the car does have a harsh ride on rough roads. Louisiana and Mississippi have crappy roads with lots of pot holes. Interstates suck big time. I'm thinking along the lines of you DG. I was thinking of going to home depot or the hardware store and looking for some general rubber bushings that are the same thickness and diameter as the original aluminum ones. I cant see paying the $80 plus for a set of rubber bushings only to have to cut the fire wall and lower the steering column. DG, did you get yours there in Metairie??
Old Jan 31, 2017 | 11:19 AM
69/03vette's Avatar
69/03vette
Here's something to keep in the back of your mind. Don't know if your going with side pipes. When I rebuilt my 69 BB I chose the rubber instead of aluminum basically for the ride, but found out later on that because of the difference in height I didn't need to modify my rocker molding for the hooker side pipes. Win, Win
Old Jan 31, 2017 | 11:48 AM
The13Bats's Avatar
The13Bats
I was bass akwards to that, i didnt want my 69 raised any i like it low it was on worn rubber so i went with poly the same size as aluminum
To Aluminum body mounts?
