First time pulling and rebuilding my engine help
Old Feb 3, 2017 | 03:24 AM
armenag's Avatar
armenag
Cruising
Default First time pulling and rebuilding my engine help
Hey guys,
After pulling into my driveway tonight I heard a loud chatter coming from the driver side valve cover of my 76' L82 stingray. This was the final straw and I decided I would be pulling my engine and rebuilding the top end (heads+camshaft, I've already swapped to an Edelbrock intake, and have flowtech heads).
I need some advice on how to pull my engine and what equipment to buy. My car is manual so after doing some research people were saying to pull the engine coupled with the transmission.
- What engine hoist and engine stand would you guys recommend buying?
- What are the steps to pulling the engine and transmission?
- Once the engine is pulled out how do you mount the engine since the bellhousing is taken up? Do you have to remove the transmission then?
- What cylinder heads and camshaft would you guys recommend for power (as well as pushrods and springs and other auxiliary parts)?
- Since I have the transmission out how hard would it be to change the clutch+flywheel?
This is my first time attempting a big job like this. Any help is much appreciated (reference material is also much appreciated!).
Thank you!
Old Feb 3, 2017 | 04:56 AM
terrys6t8roadster's Avatar
terrys6t8roadster
Engine stand; one with four wheels.
Hoist; rent one.
You don't need to remove the tranny for any of the work you described.
Heads; AFR.
Cam, lifters and pushrods; Straub Tech.
After you decide on cam profile then you talk to head manufacture to get correct valve springs.
It is always advisable to do the bottom of engine at this time; rings bearings, oil pump.
You need to decide on what kind of power you want and at what RPM you expect to achieve that power, for example; a stock rods and crankshaft is very questionable at 400HP over 6000RPM.
Engine removal; GET A HELPER, remove hood, drain radiator, mount car on quality jack stands, remove right front tire, disconnect every thing from engine. Separate the engine at bell housing, leaving the bell attached to tranny. Cut a piece of 2x4 to put under bell for support. attach engine hoist to engine[you'll note the hoist legs must enter on a diagonal basically where the RT tire was]. Lift slowly making sure you disconnected every thing. After you cleared the mounts [this is the height of that 2x4] pull engine forward to separate the tranny input shaft from clutch, now you're free to go.
Do a lot of research before buying parts, there are a lot of very helpful members here on this forum that are willing to help, any questions as you go just ask. T
Old Feb 3, 2017 | 06:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: why not determine the cause of the "chatter" and then decide whether or not you need a rebuild?
Old Feb 3, 2017 | 07:02 AM
Sluefoot's Avatar
Sluefoot
Wasn't necessary to remove hood, radiator or shroud on my '79....left the tranny under car, then sent it out for rebuild.
Old Feb 3, 2017 | 07:55 AM
Lobzila's Avatar
Lobzila
If you are dead set on removing it and rebuilding it. Remember, Youtube is your friend when you get stuck. Terry pointed out some good stuff, but I would also remove the radiator for more room.
Find a local builder and tell him what you want done. Hence, if you have a problem with the motor, you can take it back for advice and or repair as needed.
Engine removal is pretty straight forward, but a friend and cold beer will get it done quicker.
Old Feb 3, 2017 | 10:48 AM
bj1k's Avatar
bj1k
Why pull the engine if it is not using oil ? The bottom end might have already been gone through in the past and not need anything done to it. It's possible that it just needs a valve adjustment or a bad lifter. I would start by looking there.
Old Feb 3, 2017 | 10:56 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Pull the heads and inspect before you go any further......
I recommend Dart heads.......most here like AFR....to-may-toe/to-mah-toe.
I also recommend Harland Sharp rockers and Trend pushrods at this level.
Cam wise I use a few of Comps grinds (Mostly the old Magnum line) and Howard's if going for a hydraulic roller.
Straub is good at recommending cams as well if you do not want to dick with it......
I also like split guide plates.....and the ARP head bolt kits with the stainless outer bolts.
Jebby
Old Feb 3, 2017 | 02:24 PM
armenag's Avatar
armenag
Cruising
Hoist; rent one.
Heads; AFR.
I have a couple of more questions. A lot of people on this thread are mentioning AFR heads. How do Edelbrock cylinder heads compare on average to AFR heads? I noticed that AFR heads are a bit more expensive than other heads on the market.
How does this look for an engine stand (https://www.summitracing.com/parts/s...ga/overview/)?
If the goal is 400HP, will the stock pistons+crank from the L82 not support that type of power, if not what do you guys recommend?
Old Feb 3, 2017 | 07:17 PM
Giddy-up Go's Avatar
Giddy-up Go
That looks fine for an engine stand, but I would recommend searching through Craig'slist for a used one about 1/3 the price. May find a good used hoist too for cheap. You can always sell them later or keep to loan out to your friends - you know, the ones that come help you pull and drop yours in. Renting one is fine, but my projects seem to take more time than I thought they would, so the luxury of having it around whenever I want plus being able to help my friends makes it worth having it around.
Old Feb 3, 2017 | 09:07 PM
lowbuck72's Avatar
lowbuck72
Before you spend a dime, pull your valve cover and take a look. Chances are it's something very simple. It might be obvious, maybe a bent or broken pushrod, maybe a bad rocker. if it's not obvious, pull your plugs and turn over the engine with a wrench and watch the valve train in action. Still nothing. The put the plugs back in and have someone start the engine with the valve cover off and watch. You should be able to figure it out, especially with the Forum's help. Worst worst case, you will not have to pull the engine for top end work, and even then, you shouldn't need new heads, your existing heads may need repair, but most likely minor.
Old Feb 4, 2017 | 06:53 AM
terrys6t8roadster
If you are looking at a 400HP limit as your goal, from what I've read the Edelbrock heads are a very good choice. Keep in mind that 400HP is your peak HP and my question is how often are you going to demand that? Normal street driving - once in awile, spirited driving - more often, on a race track all the time. I'm not familiar with the L82 crank whether it is cast or forged. If it's forged no problem if it's a cast crank you are chancing it. Cast crank engines have cast rods and all of the SBCs that I've trashed have been do to rod failure and I did that a lot just a long time ago. Just for an example the engine I built for my 69 daily driver is a 434 and I'm sure it peaks over 400HP, all the internals are forged but to tell you the truth that if I've had the engine over 4000 RPM , well I remember 1 time for sure maybe twice. Are you looking at the complete valve train kit from Edelbrock? It's a nice kit.T
Old Feb 5, 2017 | 01:11 AM
JoeMinnesota's Avatar
JoeMinnesota
ARMENAG... How many miles on the motor? Just be aware that if the motor has high miles, uses any oil, smokes on acceleration or is generally worn, freshening heads and swapping the cam may blow the rings out of your motor in short order ... ask me how I know. Additional lift and better sealed heads can raise the cylinder pressures and take a toll on old, weak rings. On one of my first rebuilds I freshened the top end and recammed a high mileage motor and the rings let go during cam break-in, leaving a steady stream of glorious blue smoke. I ended up pulling it back out and turning it into a major rebuild.
If you're pulling it out, freshen the bottom end while you're at it, unless you're already sure it's solid and has good compression.
Old Feb 5, 2017 | 06:13 AM
scrappy76's Avatar
scrappy76
I did this once many years ago, rebuilt the top end of a motor that should have gotten a full rebuild. the newer top end was too much for the bottom end, started burning oil with 6 months.
You need to see whats wrong first, then determine a top end rebuild or full rebuild. buy a hoist and stand, either new or used of craigslist. no renting. Leave the tranny in the car, less work IMO, besides the fact you will have to take it off the motor to replace the clutch anyways, and you do not have to remove the hood or radiator to pull just the motor. I have done it twice, once with a small block and a big block. I also did not have the option of a helper either time, but if you have a helper it does go quicker unless your **** like me and prefer doing stuff yourself. IMO, Edlebrock is good stuff but not high end, its like performance on a budget, but not the same quality as high end.
To First time pulling and rebuilding my engine help
