Cleaning Coolant-soaked Carpet
Old Apr 13, 2017 | 03:07 PM
Cavu2u's Avatar
Cavu2u
Default Cleaning Coolant-soaked Carpet
This carpet is now just damp, due to a Heater Core Leak, but about 3 months ago when the leak occurred, it was definitely soaked.
Question: Will this eventually dry on it's own? Will it fade the Dark Blue color of the ACC product if I rinse it out with lots and lots of water?
New to this. Thanks folks.
Steve
Old Apr 13, 2017 | 03:36 PM
Kevin68's Avatar
Kevin68
It'll dry, but will have a sticky residue that will attract every bit of dirt.
I don't think the carpet fibers are dyed. I think they are the color you see is through and through the fibers. Remove the door sill and kick panel, rinse/soak, then vacuum with a shop vac. Repeat as necessary until any residual stickiness and smell is gone. Pull the carpet away from the floor and prop it up to make a gap. Aim a fan at the gap until the carpet and jute is dry.
Old Apr 13, 2017 | 03:47 PM
Alan 71's Avatar
Alan 71
Hi Steve,
Well, that's not very nice!
I think fellowing K68's advice is a good way to begin.
As with any cleaning on older parts, begin with the weakest solutions of whatever you choose to clean with, and still get the results you're looking for.
I'd be tempted to remove the seat and then get the carpet out where you'll likely have better success rinsing it thoroughly and then getting it to dry.
Good Luck!
Regards,
Alan
You might even try a solution of household ammonia and water. (Test a spot under the seat!!!)
Old Apr 13, 2017 | 04:25 PM
Mr D.'s Avatar
Mr D.
I will throw my .02 in here, pull the carpet out of the car to clean it.
Old Apr 13, 2017 | 06:26 PM
Cavu2u's Avatar
Cavu2u
Thanks Guys,
No doubt removing the entire carpet to clean, rinse, and dry would be the best.
But I'm lazy.
The coolant has to be removed. It IS water soluble, so water should do it. Warm to hot water might work better than cold. Then a spray-then-vacuum cleaner maybe to finish it with? I can't be the first to have had this problem, and thanks to you guys I've gained some insight on it.
Steve
Old Apr 13, 2017 | 10:50 PM
7T1vette's Avatar
7T1vette
Remove the carpet. That is the EASIEST way to get the carpet completely rinsed out and thoroughly dried. Anything you do while it is still in the car will not be enough.
Old Apr 13, 2017 | 11:14 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I agree. That's what I did on my 78 after living with the grimy feel for years.
Hung it over the fence and thoroughly flushed it with water till it felt clean.
Some of the color came out so I spot sprayed it with spray "dye" and it turned out great.
Old Apr 14, 2017 | 12:07 PM
REELAV8R's Avatar
REELAV8R
Originally Posted by Cavu2u
Thanks Guys,
But I'm lazy.
Steve
I seriouly doubt this, but I can relate.
Any how, I purchased one of these Bissell little green machines several years ago and I have used for cleaning cars many times.
It's really pretty impressive for such a small machine. It delivers heated water and detergent to the area you are woking on with a brush scrubber built into the handle and it does a really good job of getting out stains that I thought would not come out. Pretty strong suction removes all the water (still damp of course) and only delivers the amount of water you command with a trigger on the wand.
I've gotten out stuff like grease, soda pop and ground in dirt on car carpets.
Don't know it you want to pop $90 for it, but I have not regretted my purchase of it so far.
I got mine at Target IIRC and the cleaning solution can be had there as well.
Amazon Amazon
Old Apr 14, 2017 | 01:37 PM
Cavu2u's Avatar
Cavu2u
https://www.amazon.com/BISSELL-ProHe.../dp/B002KCMH6Q
You gave me a GREAT idea my friend. I've already got a steam carpet cleaner, stowed away in a closet in a back bedroom, that I haven't used in years. It's got a small "Spot Use" attachment for it. All I can do is try it. I'll go thru a couple quarts of solution in cleaning it, fan dry it, and see if any residue is left on it. Will have to clean the floor underneath of course, but I'll do a lot before ripping out the console (with Center Dash too ) and the seats.
Your suggestion jogged my feeble memory. Much appreciated sir.
Steve
Old Apr 14, 2017 | 03:22 PM
KapsSA's Avatar
KapsSA
If you're that adamant about not removing the carpet, try a garden hose and a GOOD shop vac.
Thoroughly soak the area and vac it up several times.
Probably no need to SCRUB the carpet OR add any other cleaners to it.
Did that when my wife spilled a crock pot full of soup on the rear floor of my daily driver Malibu.
Old Apr 14, 2017 | 04:29 PM
Cavu2u's Avatar
Cavu2u
Thanks Kaps. Another good way to handle it.
Steve
Old Apr 14, 2017 | 05:22 PM
Alan 71's Avatar
Alan 71
Hi Steve,
TYPICALLY the carpet only extends up under the console an inch or 2.
In you look carefully you might well be able to carefully pull the carpet from under the console to give you better access to the carpet, the pad and the floor.
Regards,
Alan
Perhaps this will give you an idea how much of the carpet is typically tucked under the console sides.
Old Apr 14, 2017 | 06:12 PM
Cavu2u's Avatar
Cavu2u
Originally Posted by Alan 71
Hi Steve,
Regards,
Alan
Thank you Alan. I'll be able to do exactly that!
Steve
Old Apr 14, 2017 | 06:44 PM
7T1vette's Avatar
7T1vette
Soaking the carpet in place doesn't consider the jute insulation material under the carpet. I've used carpet cleaner machine on mine too; but I just needed to clean the upper portions of the carpet...not completely soak and rinse the entire carpet.
Wish you luck with whatever you decide.
Old Apr 14, 2017 | 09:25 PM
M A Fry's Avatar
M A Fry
Hi Cavu2u,
I had this exact same problem happen to me a few years ago to a brand new set of carpet. I removed the carpet and rinsed with the garden hose and let it sun dry.
Mark
Old Apr 14, 2017 | 09:30 PM
REELAV8R's Avatar
REELAV8R
Hope it works. I'm always a fan of a simple solution too.
Old Apr 14, 2017 | 09:46 PM
KapsSA's Avatar
KapsSA
The jute padding gets soaked with anti freeze too.....
To Cleaning Coolant-soaked Carpet
Old Apr 14, 2017 | 09:51 PM
dmaxx3500's Avatar
dmaxx3500
you need to take it and the padding out and wash in warm wter,and then wash the fiberglass floor with simple green and water too
Old Apr 15, 2017 | 08:41 AM
momo608's Avatar
momo608
A new front carpet set is about $190. I wouldn't waste anymore time on that old carpet. Good time to put some heat resistant sound deadener in while your at it. It's a good feeling when a problem happens that requires repair to make whatever it is better than it was before. Beats a day wasted in front of the boobtube for sure.
Old Apr 16, 2017 | 05:44 PM
Kevin68's Avatar
Kevin68
Steve
I'd definitely give this a try, although the soaking and vac will do the same thing. As you noted, it is water soluble. If you use a hose, don't overfill the foot well so it spills in the seat well, or you will be pulling the seat. Also, keep in mind that you want to minimize letting water wick up the jute. You could also pull the floor plugs and get a better rinse.
The "pull the carpet" or "replace the carpet" options are still there if you are not satisfied with the results with no harm done other than an hour or two of wasted time. I understand you are lazy, but I would invest an extra 5 minutes in this project and remove the door sill and kick panel to separate the carpet and jute. Fan dry for several days if necessary. It won't be as pretty as new carpet, but if you do it right it won't smell like a locker room either.
