Rocker Panels
Old May 2, 2017 | 09:09 PM
blanman61's Avatar
blanman61
Default Rocker Panels
Think my black 78 would look good with some chrome rocker panels, but never seen any available for my year.
looking for ideas or pictures
Old May 2, 2017 | 10:52 PM
Metalhead140's Avatar
Metalhead140
C3 of Year Finalist (track prepared) 2019
https://www.corvetteforum.com/forums...7-to-78-a.html
Old May 3, 2017 | 05:27 PM
blanman61's Avatar
blanman61
Thanks Metalhead140, a lot of good info, much appreciated
Old May 3, 2017 | 07:18 PM
theandies's Avatar
theandies
I can measure my '71's if you want. That way if you want to buy some you'll at least know if they will fit.
Old May 3, 2017 | 09:20 PM
oldgto's Avatar
oldgto
I can pretty much tell you that the 71s are shorter than later 70s. I was given a set from 77-80 in good shape... but they were too long for my 71. I bought some correct ones from a forum member for my 71.... and side by side, there`s a couple inch difference. The longer set I then sold to another forum member.
Old May 4, 2017 | 04:33 PM
oldgto's Avatar
oldgto
OK... the rocker moldings on my 71 coupe are 65 1/4" long.
Old May 4, 2017 | 05:17 PM
7T1vette's Avatar
7T1vette
All you need to do is remove the black paint. Use a chemical stripper, rather than to try sanding the paint off. If you sand, you will damage the coating on the aluminum. Just strip the paint off and repaint the black stripe with semi-flat or satin black paint.
To Rocker Panels
