I want to buy a C3 - but I don't know what I'm getting myself into.
#41
Well guys, I did it. I bought a C3.
A '79 black C3 with red leather interior with the L82 255hp engine, manual transmission, and 100% completely original except for the steering wheel (but he gave me the old one - just some cracked leather). Got it for 8,700 off a private seller. Only a few tiny issues - parking brake doesn't work, a tail light is out, clock on the inside doesn't work, and the paint is not perfect (but like I said, all original). I will probably need to replace the tires since they are original...
65,000 miles on this thing, two owners, the guy I bought it from owned it for 25 years and put 35,000 miles on (drove it 5 times a year, only in sunshine, kept it in a heated garage). This car has never seen rain - the birdcage was shiny still.
I think it's perfect. I am also happy I didn't break the bank (12,000 was my max). The car looks and sounds like a demon. Drives strong - I drove it 2 hours home all over the place. I am so happy! Thanks for all the advice guys!
MISTERZ06 (05-24-2017)
#43
I dig it, black/red looks sharp... doubt the tires are the original though. Your rims aren't stock for 79. However, I don't think they've made those Eagle ST's since around 2000... so yeah they have to go.
#44
Interesting - well that is also good to know. I was shocked to think that those tires have been on for 65,000 miles
#45
Looks great in the picture.
Clock can be sent out for conversion or just getting it fixed.
Parking brake could be just an adjustment but get underneath it and check the cables and brake shoes.
#46
Glad you found your car!!!!
After tires, your first purchase needs to be both the factory service and assembly manuals. They are invaluable.
The clock and parking brake are excellent repairs on which to cut your teeth.
Original clocks and can sometimes have a lasting repair made by simply cleaning and lubricating. Do a bit of searching here and you'll find excellent instructions. It's a good idea to leave the clock running on the bench for a few days before putting everything back together as such repairs aren't always successful for any length of time.
Parking brakes are another very common problem. Presuming it leads to the shoes and associated mechanism itself (likely) you can prepare for one of the frustrating Corvette repairs. Presuming things are as untouched as you say the rotors will be attached with rivets that must be drilled out (you don't replace them however). When it comes time to reassemble the mechanism search here for "parking brake dental floss" for an excellent idea to turn an extremely frustrating job into something much less so.
Post pics of your engine compartment when you can. Such is an excellent indicator of how original things really are.
It doesn't matter but pinstriping did not come from the factory.
#47
Very interesting to know that the pinstriping did not come original. I'm thinking the original owner pimped this thing out a bit before selling it to the guy I got it from - hence the nice hub caps and sleek stripes. Hopefully something like that won't hurt my chances at the collector plates.
I am not too worried about the clock and parking brake for now (first gear works fine for that purpose) but I will likely want to fix that in the future, so thank you for the advice! I am new to the car fixing thing so it is greatly appreciated.
I will be taking better photos tonight to get it insured at what it is worth, so I will be sure to share updated photos.
Thanks everyone for sharing my excitement and celebration!
#48
I think I might have the manuals actually. Letting my fiance drive it last night I poked around in the glove compartment and it was packed with some sort of manuals. I do have to get in there and figure out how all the inside stuff works (so I can roll down the windows while driving without having to think about it - the placement of some things is odd! still don't know how to turn on the inside light).
You turn on the inside lights by turning the headlamp **** all the way counter-clockwise. Such is also the dimmer for the dash lamps--the farther clockwise you turn the brighter.
If that doesn't turn on the interior lights (and they don't turn on with the doors opening) then say "hello" to yet another extremely common problem--some sort of fault in the CTSY (courtesy/accessory) circuit that either causes the battery to drain or the fuse to blow.
#49
Congratulations it looks like a great purchase for $8,700.
MISTERZ06 (05-23-2017)
#50
Each of those manuals have hundreds of roughly letter-sized pages. They won't fit in the glove box.
I knew that **** did something...thought it was just loose or something. Gotta love the beautiful simplicity of the controls in these cars!
Well, that interior light problem doesn't sound like one that is worth fixing unless it does something more than not let the light turn on. That plus the clock are low on the priority list.
Today the little reverse pull **** thing on the shifter snapped, but I just had to unscrew the **** and see exactly what part to buy and it was only 16 bucks. These cars are like, designed to fix. I love it. I think I bought more than my dream car, but I bought something I can fix and be proud of!
#51
Here it is! Not the shiniest...
Also, there is a plastic piece directing air across the engine that the old owner took off - I have it.
#54
Zora signed your steering wheel?
#55
clypsedra (05-23-2017)
#58
Thankfully it didn't rain - I don't want this car to ever see rain. Unfortunately, the forecast for the week is nasty so looks like she will be sitting inside for a while I am itching to get out on the road!
#60
Received 1,470 Likes
Cruise-In II Veteran
