I Hate Plastic Clutch Alignment Tools
http://www.corvetteforum.com/forums/...s-bushing.html
DUB
Great info here on the forum.....
Before you start to assemble your clutch, you need to make sure that your pilot bearing/bushing and clutch disc slide onto the input shaft smoothly and easily. If not, fix it now. When using the plastic clutch tool you have to realize that it is a somewhat loose fit. Lightly snug the pressure plate bolts until the clutch disc is being held by the plate, but will move when slight side force is applied.
Use your clutch tool and move it up and down, left and right while observing how close the tool gets to the pressure plate springs or forks. I'm going to call this slop an "orbit". Now use the clutch tool to move the clutch disc so it is in the center of the "orbit" you just observed. Remove the tool and torque your pressure plate to specs. I recommend using locktite and a torque wrench as these bolts aren't very big and if you break one you won't enjoy it. Install the tool and make sure it slides in nice and easy. Slightly lube the pilot bearing/bushing and clutch splines. If you overlube the pilot, it will hydraulically keep the pilot shaft out. While you guide the transmission in, make sure you keep the transmission aligned with the centerlinbe of the crankshaft both up and down and left and right.
When I was a tech I replaced hundreds of clutches. In the "old days" clutches didn't come with a clutch tool and if the parts store didn't have tool in stock I'd just use a 3/8 inch extension and use this method. It works, every time. Having a good jack and good lighting and experience also helps.
I've been using an old front shaft I remove from a transmission back in the 70's
works great but you still have to "wiggle" and be sure it slides in/out smoothly.Once you get clutch bolted/torqued transmission should slide in with no problem.
George
