Window scratches
Old Jun 9, 2017 | 02:42 PM
crawfish333's Avatar
crawfish333
CI 6-7 & 9 Veteran
Default Window scratches
I am thinking about getting the motor rebuilt (hopefully) or replaced as it goes up very sluggishly. the window on that side has also scraped on the weather stripping and has what looks like streaks or scratches on it. I am inclined to go ahead and replace weather stripping in both windows whiel I am at it. The window is original and still has the "Astro Ventilation" markings on it.
Is there any way to get rid of those streaks on the window without replacing it? I do not want to lose the "Astro Ventilation" markings on the window by buying an aftermarket piece.
Old Jun 9, 2017 | 03:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Light scratches will sometimes polish out. Deeper ones usually do not.
Old Jun 9, 2017 | 03:36 PM
Alan 71's Avatar
Alan 71
Hi c,
Several suppliers sell kits to use to remove 'marks' on the glass.
It's a polishing process that takes a long time (hours).
Generally people report that if the scratch can catch your fingernail it can't be completely removed. But polishing it rounds the edges of the scratch so the light doesn't catch it so easily so it's not so obvious.
There are vendors selling new side glass that has the Astro logo and also the manufacturer's logo and date.
Regards,
Alan
Old Jun 9, 2017 | 06:54 PM
ballen06's Avatar
ballen06
I have the same issue. What companies sell this glass? I would be interested.
Old Jun 9, 2017 | 07:03 PM
billcarson's Avatar
billcarson
as the faithful have said you can lessen it but not fully remove it,i tried real hard.i solved the problem by driving with the windows open and because i am claustrophobic it worked for me.
Old Jun 9, 2017 | 07:40 PM
OldCarBum's Avatar
OldCarBum
I've seen them through Corvette Central.
I'm looking to replace mine as well.
Replacement glass is reasonable, with the Astro Logo, Is more.
Old Jun 9, 2017 | 09:28 PM
lowbuck72's Avatar
lowbuck72
I had wiper blade scratches on my '55. Bought a scratch removal kit from J.C. Whitney. It worked but it took a lot of time and patience. It came with a hard cylindrical polishing pad on an arbor that fits an electric drill. Also came with a jar of brown compound.
Old Jun 9, 2017 | 10:01 PM
RJ1AZ's Avatar
RJ1AZ
From: PHOENIX, AZ Yes, it's true. You are a good woman. Then again, you may be the Antichrist.
I had some good scratches on the passenger window of my old C5. I had a tub of polishing paste and figured it couldn't hurt to try it. Took some time and elbow grease, but I was very pleased with the results.
Old Jun 10, 2017 | 08:43 AM
Street Rat's Avatar
Street Rat
I just replaced my right door glass and associated parts. I got it all from CC.
Old Jun 10, 2017 | 05:58 PM
7T1vette's Avatar
7T1vette
If you have vertical scratches on the side windows, the felt bumpers are not adjusted properly or the felt is 'shot'. You need to get those fixed or a repaired [or new] window will do the same thing.
Old Jun 10, 2017 | 06:23 PM
crawfish333
CI 6-7 & 9 Veteran
Yes they are being replaced along with the new window motor.
Old Jul 11, 2017 | 11:13 AM
crawfish333
CI 6-7 & 9 Veteran
Update: After a thorough cleaning and some light polishing, it seems my streaks were not scratches at all. My passenger side window now looks like new on the outside. The inside was already OK. Along with the new motor, I am going to replace the outer rubber seals and I would also like to replace the inside part. Does anyone know what that part is called on the inside that the window sides up and down on?
Old Jul 11, 2017 | 04:40 PM
SwampeastMike's Avatar
SwampeastMike
I believe they're called "front vertical track" and "rear vertical track". I have not seen them for sale by the vendors. If the window struggles up but goes down quickly then the assist spring is most likely broken. Cleaning and relubrication of the entire mechanism is probably called for as well.
To Window scratches
