Interior panel paint tip.
Old Jul 6, 2017 | 04:30 PM
540 vette's Avatar
540 vette
Default Interior panel paint tip.
I had some scratches in the rear quarter trim on my 72. A couple of the guys here suggested to fill the scratches with some filler. Did that but lost the grain. When I painted the parts they looked to smooth.
I got some bed liner paint in a rattle can and gave the area that I fixed a light dusting. Just enough to make it a little rough. And not heavy. Then painted with interior paint. Came out looking pretty good. It gives it some texture and it looks good from 5 inches away.
Old Jul 6, 2017 | 05:16 PM
Dean_Fuller's Avatar
Dean_Fuller
Thanks for the tip. Sounds like a good idea! I am in the process of painting several interior parts myself.
Old Jul 6, 2017 | 05:50 PM
540 vette's Avatar
540 vette
I also use Easy Off oven cleaner to remove old paint. Yellow can. Won't hurt the plastic.
Old Jul 6, 2017 | 06:53 PM
raydog9379's Avatar
raydog9379
And use some adhesion promoter... otherwise it just flakes off with the slightest rub. Found that out and some guys who are painters on here gave me the tip.
Old Jul 6, 2017 | 10:33 PM
540 vette's Avatar
540 vette
Never used it. Never had any problems.
Old Jul 7, 2017 | 12:09 AM
7T1vette's Avatar
7T1vette
I guess you missed the step in your prior thread about using a stiff brush to knock off 'excess' filler while it was still pliable (before setting up completely). That would have recovered the graining in the surface.
Old Jul 7, 2017 | 06:11 AM
540 vette's Avatar
540 vette
Didn't have excess filler. The one area had a chunk of it missing and the other area had some deep scratches. The grain was lost from them before I started.
Old Jul 7, 2017 | 12:45 PM
7T1vette's Avatar
7T1vette
If, when you put on the filler, you 'lost' the surface grain...you had excess filler. The stiff fiber bristle brush removes the filler that sits between the peaks in the grain and will tend to blend-in areas that have been repaired.
To Interior panel paint tip.
