Battery
Old Jul 13, 2017 | 12:31 AM
Z06LMB's Avatar
Z06LMB
Default Battery
Aside from what the manual says and just like tires, most have deviated from what came with your cars.
What size battery or group size, CCA?
Top or side posts?
Recycled lead or virgin lead batteries like Diehard Premium?
I claim ignorance on the subject of Optima batteries and their benefits for use in early C3 cars. At this moment I can't see justification to spend twice as much for a part time use vehicle.
Old Jul 13, 2017 | 07:29 AM
Alan 71's Avatar
Alan 71
Hi,
"Top or side posts?"
On 68-72 cars the configuration of the battery cables dictates whether a top terminal or side terminal battery is used.
For example, the cables in 70-72 cars are for use with side terminal batteries.
Regards,
Alan
Old Jul 13, 2017 | 07:53 AM
xpoc454's Avatar
xpoc454
On my 69 the cables are side post. This makes connecting the battery quite a bit more difficult. I always assumed they were all side post for convenience? Was it common for them to be side posts?
Old Jul 13, 2017 | 09:07 AM
Alan 71's Avatar
Alan 71
Hi x,
The batteries used during the 68 model year production were of the top post configuration.
Top post batteries continued to be used during 69 model year production until about car # 22000 when the change to a side terminal battery was made which continued in use through at least the 72 model year production.
Regards,
Alan
Old Jul 13, 2017 | 09:20 AM
Tiger Joe's Avatar
Tiger Joe
early cars called for a group 24 battery, not sure if that changed. I can easily fit a group 34 in my 68 battery box with no worries of the top terminals hitting.
a battery is one of the things I never cheap out on. I run Ac Delco batteries in just about everything, and I put an antique auto battery i my vette. Modern battery made to look original. Its pricey but they claim they will hold a charge up to a year.
FWIW- I used to love optima batteries, I have one approaching 10 years old that is still good. 2 months back bought a brand new yellow top, dead cell right out of the store.
Old Jul 13, 2017 | 09:43 AM
Street Rat's Avatar
Street Rat
Optima Yellow D34/78, 750 CCA
Top and side post connections
AGM deep cycle
Old Jul 13, 2017 | 01:47 PM
ntfday's Avatar
ntfday
Veteran: Marine Corps
I have a 78 series side post in my 76.
Old Jul 13, 2017 | 03:55 PM
xpoc454's Avatar
xpoc454
My vin is around 19000. It has side posts cables in it. So I guess maybe someone changed mine? They don't look new but even an old changeover wouldn't look new I guess.
Old Jul 13, 2017 | 04:00 PM
7T1vette's Avatar
7T1vette
Wherever you buy the battery, they should have a catalog that details the correct battery for your car.
I get my batteries at Wal-Mart. They're made by the same mfgr., have a decent warranty, and are reasonably priced. Been doing that for years with no problems.
Old Jul 13, 2017 | 04:15 PM
Alan 71's Avatar
Alan 71
Hi x,
Sometimes you have to believe the car.
While I'd expect to see top terminal cables in your car????
I guess you could look closely to see if there are signs that they were replaced.
Regards,
Alan
Old Jul 13, 2017 | 05:21 PM
69L46's Avatar
69L46
2015 C3 of Year Finalist
St. Jude Donor '15-'16-'17-'18-‘19-'20-'21-'22-'23
My '69 built in Jan 1969 and uses the top post style. It did have side terminals when I initially got the car, but after having to replace the cables I went with the correct ones. Easier to keep a trickle charger on anyway.
And replacing that positive cable is not something I want to repeat anytime soon...
Old Jul 13, 2017 | 05:49 PM
Mr D.'s Avatar
Mr D.
Hit the easy button and go to walmart and buy a battery.
Old Jul 13, 2017 | 05:58 PM
71 Green 454's Avatar
71 Green 454
Same here, for the Corvette and 2 Mercedes. My '71 is a side post and the last battery was a Maxx 75S at Walmart.
https://www.walmart.com/ip/EverStart...264#about-item
Old Jul 13, 2017 | 10:42 PM
Tim81's Avatar
Tim81
I also have cheaped out and purchased a Wal-Mart battery for my 81, so far so good well see how long it last.
Old Jul 14, 2017 | 01:48 AM
Z06LMB's Avatar
Z06LMB
I have a van that hasn't been used much during the last 3 years. The battery (Max from Walmart) has been discharged completely and sits sometimes for months at a time between jump starts (3 - 4 times) but this week this battery won't hold a charge and I had to replace (bought 01/11).
Old Jul 14, 2017 | 06:07 AM
oldgto's Avatar
oldgto
It`s not so hard..... when the transmission is out of the car!
Old Jul 14, 2017 | 10:27 AM
joewill's Avatar
joewill
from a CCA point of view, buy you the biggest CCA you can find for your budget.
if your car sits a lot then you will see the difference in the car barely starting in 2 weeks with a cheaper battery, vs 4 months from now ( or sitting all winter like mine does ) a high CCA battery will still start your car.
To Battery
Old Jul 14, 2017 | 11:39 AM
REELAV8R's Avatar
REELAV8R
The highest CCA battery that will fit in the space from Walmart. Been in there for 5 years now.
You can spend more $$ on a battery but it doesn't mean it's a better battery.
I have a Walmart battery that is 13 years old and still holding a charge.
Old Jul 14, 2017 | 02:12 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Exactly.......and use a quality trickle charger!
Old Jul 14, 2017 | 02:38 PM
7T1vette's Avatar
7T1vette
If the car sits a lot, you should either put a GOOD trickle charger on it (a cheap one will overcharge the battery and kill it just sitting there) or have a battery disconnect. I have the latter and have no problem starting the car...even if it has sat for a couple of months or more. The disconnect also makes it convenient to work on anything electrical without having to REMOVE battery cables.
