A/C system...
Old Jul 31, 2017 | 08:24 PM
clajac's Avatar
clajac
Default A/C system...
When adding oil to an ac compressor what would be the normal amount of ounces to add and what type would you suggest. this is for a c3 system.
thks
Old Jul 31, 2017 | 10:17 PM
7T1vette's Avatar
7T1vette
Do you know what kind of refrigerant was in the A/C system previously? The C3 cars were built using R-12 refrigerant and mineral oil (#525 compressor oil; 11 ounces in the 1971 system). But, any stock system can be converted to use R134a refrigerant, which must use PAG oil, instead. The two different oils do not mix and the system must be cleaned to do the switchover. So, you need to know what was in it, so that you can re-fill with the correct oil.
Old Jul 31, 2017 | 11:00 PM
REELAV8R's Avatar
REELAV8R
Ester oil is compatible ( can be carried by) both freon types.
What year we talking about?
Is the system empty of oil or are you adding due some loss?
Old Aug 1, 2017 | 08:00 AM
clajac's Avatar
clajac
I have completely removed the entire system and thoroughly cleaned both the eva & cond and installing a new accumulator and rebuilt compressor.
Old Aug 1, 2017 | 08:38 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
My 68 calls for 8 oz of ester oil. I'm staying R-12.
3.25 lbs of Freon.
Marshal
Old Aug 1, 2017 | 11:14 AM
REELAV8R's Avatar
REELAV8R
Since it's empty you can add whichever oil is appropriate to the refrigerant being used.
PAG for 134a
Mineral for R-12
Ester for either one.
If there is any doubt about the system being completely clean of mineral oil for a R12 to 134a switch then use the ester oil to prevent oil incompatibility problems.
Can't answer the quantity question without knowing the compressor type.
A6; long skinny or R4; short fat.
Old Aug 1, 2017 | 05:58 PM
REELAV8R's Avatar
REELAV8R
Had a chance to look it up this afternoon.
According to my 77 service manual;
R4=6oz of oil
A6=10.5 oz of oil
If using PAG it looks like the recommend wt is usually PAG150.
Old Aug 3, 2017 | 08:56 PM
clajac's Avatar
clajac
Thks fellows, great help. Its and R4 system completely empty...........
To A/C system...
