Rubber Carpet Fasteners
Old Aug 5, 2017 | 02:37 PM
70 Sting's Avatar
70 Sting
Default Rubber Carpet Fasteners
Here's perhaps a silly question: How do you install these things?
I've tried pushing them in by hand and using a screwdriver (which poked through the back).
Doesn't help that I'm working in the rear compartment (C3).
Thanks!
Old Aug 5, 2017 | 03:27 PM
exposingtime's Avatar
exposingtime
2015 C3 of the Year Finalist
I used a 6 inch long bold that fit nicely into the opening of the plug. I used a nut to properly position a wide washer over the head of the rubber plug, allowing it to go all the way in, essentially creating a stop. Dipped in dish soap, pushed into place as far as possible and gave a light tap with hammer.
Gary
Old Aug 5, 2017 | 03:40 PM
Alan 71's Avatar
Alan 71
Hi 70,
There's a small tool that some vendors sell that is a 'bought' version of what ex describes.
Use something (a bolt) that's smaller in diameter than the hole in the plug so the rubber has a little room to 'collapse' as you push the plug through the hole in the fiberglass.
Regards,
Alan
Old Aug 5, 2017 | 03:46 PM
70 Sting's Avatar
70 Sting
Thanks for the replies, fellas. I found this short length of rod and wore some work gloves to save my hand. A bit snug pulling it back out but it did the trick.
To Rubber Carpet Fasteners
