1969 transistor ignition help
Thanks,
Clayton
Cars that had the K66 transistor ignition option had a separate ignition harness that was added to the standard engine harness.
I looked at the 1969 AIM sheets for the Transistor Ignition Option, specifically UPC K66, Sheet A3. It appears the original parts of the engine harness remained in place. I can't see anything that appears to have been cut.
I think I'd begin by removing the transistor ignition harness and then see what parts of the engine harness are still there. Might it just be the connections for the standard coil?
It appears there's also a connection that runs to the ignition switch that may need to be dealt with.
Good Luck!
Regards,
Alan
https://www.corvetteforum.com/forums...tion-help.html
