1977 rocker panels
Is there anyway to refinish these and or get the light scratches out.. Thanks
Welcome!
First post!!
The rocker trim panels are clear anodized.
This is a difficult finish to duplicate without stripping off the existing anodizing, refinishing the aluminum surface, and then re-anodizing the panel.
People report achieving a similar finish at home with clear paint.
You might want to 'search' the forums for "rocker trim/anodizing"
Regards,
Alan
These are restored/re-anodized rocker trim.
You and your wife could go away for a VERY nice weekend for what they cost.
Welcome!
First post!!
Regards,
Alan
If you'll go to Lowes to to the section where the sell the tool boxes you will find a product called Diamond Brite truck tool box polish !
It's a white liquid in a dark blue bottle ! You apply it with a soft cloth like t-shirt material! It's non abrasive and should not remove the anodizing on the metal but it will bring back the shine ! You'll want to do this by hand and not with a machine!
It only takes a small amount on the rag and rub ! As you do it will turn black so hospital gloves are recommended! The more you rub the better the shine ! After a few minutes you stop and let it haze over , then wipe with a clean rag !
This stuff won't scratch chrome but will remove rust from it !
2 questions I have the hood seems low in relationship to fenders I'll try to post pics and the windshield outside pillars seemed messed up
77 cars had stainless steel exterior windshield trim that was painted flat black.
What's shown in your photo is difficult to see.
It may be the correct trim that's been poorly repainted?
Regards,
Alan
I agree with other on the side trim, its been poorly painted.
I do not want to bend it.
You're going to need to be careful using the rubber blocks.
Since the hinged end of the hood is at a fixed height what the blocks are going to do is cause the hood to be 'warped' up in the center when the hood latches are set. (This will raise it in the middle.) But this is going to put pressure on the hood when closed.
The a-pillar ss trim is secured in place by hidden screws that are under the the weather stripping.
Regards,
Alan
The rubber strip and it's retainer must be removed first.
Reshaping the hood to fender height is not an overnight process. What I have seen done with good results is use some of the hard white Styrofoam used in packaging. Cut some blocks that will fit into the fender gutter at the low spots, cut them just high enough to add a little pressure on the hood. No need to use any adhesives. After a few weeks cut some more blocks just a little higher and so on until the panels match. Now you can install the correct rubber blocks.
Welcome!
First post!!
Regards,
Alan
Because the aluminum is so fragile I would start with lacquer thinner to see if that will 'lift' the paint.
If that doesn't work I'd try some citrus based paint remover.
Citrus-Strip is a little gentler since it doesn't contain methylene chloride.
Good Luck!
Regards,
Alan
Good Luck!
Regards,
Alan
