Engine removal/replacement
Old Dec 11, 2017 | 10:21 PM
mci5c's Avatar
mci5c
Default Engine removal/replacement
Hi,
Im thinking of installing a crate motor in my 80, do some detailing, etc...
Which is the most preferred method? pull engine, pull engine and transmission together, or pull the body off?
Thanks Much
Chris
Old Dec 11, 2017 | 10:29 PM
7T1vette's Avatar
7T1vette
If you are going to install a crate engine, do the detailing when the engine is OUT. Also detail the new engine, as it will only come with some cheap paint on the block. Whether you pull the transmission or not is your call, depending on if it is manual or auto and on whether the trans/clutch/converter needs any work or not.
Old Dec 12, 2017 | 06:52 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
heres an active thread on removal over in the tech section.
https://www.corvetteforum.com/forums...and-trans.html
i repainted my motor and cleaned up the engine compartment with the motor out. very easy when your standing where the engine belongs. I also replaced my heater core while it was out
To Engine removal/replacement
