VIN location on frame
Old Jan 27, 2018 | 05:52 PM
RS16017's Avatar
RS16017
Default VIN location on frame
Could anyone tell me where the VIN stamped into teh frame is located on a '71 Corvette. I here there are a couple different places to look.
Old Jan 27, 2018 | 06:00 PM
gleninsandiego's Avatar
gleninsandiego
On my 69 it is on top of the frame ahead of the drivers side rear wheel.
I don't know how you could see it with the body on
Glenn in San Diego
Old Jan 27, 2018 | 06:32 PM
DUB's Avatar
DUB
It is on the top of the frame on the drivers side rear wheel area.
I have seem them near the number four body mount area....either a little ahead of it or a little behind it.
And it may take a bit of looking due to in many cases that I have seen the numbers are rather faint and not so well pronounced.. BUT...with that...it is on top of the frame by the rear wheel on the driver side.
DUB
Old Jan 27, 2018 | 06:35 PM
Alan 71's Avatar
Alan 71
Hi RS,
Welcome!
First Post!
As gw indicated part of the car's vin was stamped on the frame rail just forward of the #4 body mount.
Depending on it's condition it can sometimes be seen using a mirror even with the body in place.
There is another stamp on the left side frame rail right about where the driver's left hip would be sitting in the car. I don't think it's possible to see this one with the body in place.
Good Luck!
Regards,
Alan
Rear of left wheel well.
Old Jan 27, 2018 | 07:06 PM
BKarol's Avatar
BKarol
Alan's mirror is showing this area:
Old Jan 27, 2018 | 08:39 PM
CanadaGrant's Avatar
CanadaGrant
On my 69 the vin is in the exact same place as in Alan's photo and is readable with the same type small dentists mirror.
Old Jan 27, 2018 | 08:43 PM
RS16017's Avatar
RS16017
Are there any other places on the car that has a stamp.
Old Jan 27, 2018 | 09:01 PM
Tewski's Avatar
Tewski
Veteran: Marine Corps
St. Jude Donor '06 thru'17, '23-'26
The only place I found it was right above the #4BM DS
Old Jan 29, 2018 | 12:11 PM
Wee's Avatar
Wee
Here is mine....I used Alan's photo to find mine.
Brian
Old Jan 29, 2018 | 01:03 PM
Dynra Rockets's Avatar
Dynra Rockets
No. Those are the only two (other than the vin on the dash and the vin printed on the tank sticker)
Old Jan 29, 2018 | 06:56 PM
DUB's Avatar
DUB
Unless you want to consider...the engine block...the transmission case....unless I missed something where this was discussed.
DUB
To VIN location on frame
