Carb
Old Apr 12, 2018 | 12:33 PM
Justin97's Avatar
Justin97
8th Gear
Default Carb
Hello,
Looking for some advice on replacing the carburetor on my 75 stingray. What brand etc. Looking for a little better fuel efficiency and power. Thanks!
Old Apr 12, 2018 | 01:11 PM
KenSny's Avatar
KenSny
A Qjet is pretty efficient if setup correctly. Maybe you need a quick rebuild.
Don't look for a carb change to give you a power boost.
Old Apr 12, 2018 | 02:54 PM
7T1vette's Avatar
7T1vette
If you have a Q-Jet on the engine now, spending money for a "better" carb with more potential for power and better efficiency would be a total waste of your funds. Rebuild the carb or send it to Lars to rebuild it.
There is NO CARB MADE that will outperform the Q-Jet for smooth transitions, power, or efficiency. They may be easier to work on; but once the Q-Jet it tuned properly, you won't have to touch it again.
Old Apr 12, 2018 | 03:03 PM
dochorsepower's Avatar
dochorsepower
I agree. If the Q-jet is original to your 75, save yourself a lot of grief and have a competent source like Lars rebuild it. You can make better improvements in other places, like getting rid of the emissions crap and revising the timing.
Old Apr 13, 2018 | 11:06 PM
7T1vette's Avatar
7T1vette
You don't even have to strip off the emissions stuff. (And you don't want to if your state requires emissions testing of your vintage car.)
But, you DO want to move the vacuum hose for the distributor advance can over to a manifold vacuum source on your Q-Jet (instead of the 'timed' /ported vacuum line as it came from the factory). Doing so will put vacuum advance back on the engine at idle, which will improve idle quality, let engine run cooler, and reduce fuel usage at idle.
Old Apr 14, 2018 | 08:15 AM
pigfarmer's Avatar
pigfarmer
Originally Posted by Justin97
Hello,
I'd rebuild what's on there - it's been there a long time. No idea what you have but rebuilding a Holley 4160 cost about $30 and was straightforward. Feels like a new pair of sneakers.
I looked through replacements and like some of the Holley Quick Fuel Slayer carbs. At least with the rebuild I didn't have to fool with different cables, brackets, etc. Minor.
Old Apr 14, 2018 | 08:37 AM
Cavu2u's Avatar
Cavu2u
Justin,
My 383 lost over 30 HP on the Dyno by swapping out a Q-Jet with a Holley 6210. And one could tell the difference in road performance too.
Steve
Old Apr 14, 2018 | 08:41 AM
Pa'svette's Avatar
Pa'svette
St. Jude Donor '16-'17-'18,'19
Just send to Lars. He did mine and it runs great.
Old Apr 14, 2018 | 09:38 AM
REELAV8R's Avatar
REELAV8R
Q-jet for sure. Done right that carb is fantastic!
I'm at 440 HP and get 19 MPG @ 80 MPH with a Th350 and a 3.55 Rear diff.
Old Apr 14, 2018 | 05:47 PM
mrmagrath's Avatar
mrmagrath
Rebuilt my own Q-Jet using Lars' papers. Awesome.
Old Apr 15, 2018 | 10:08 AM
REELAV8R's Avatar
REELAV8R
If you are a DIY kind of guy I rebuilt and modified mine using this book from Cliff Ruggles. Turned out great.
Amazon Amazon
Old Apr 15, 2018 | 01:06 PM
Black$heep's Avatar
Black$heep
Anyone have Lars contact info or page link? What does it run? Considering a rebuild!👍🏼
Old Apr 15, 2018 | 05:29 PM
lars's Avatar
lars
Just drop me an e-mail for info.
Lars
V8FastCars@msn.com
Old Apr 15, 2018 | 08:38 PM
Inca32x's Avatar
Inca32x
If the carburetor is the correct qjet for 75 automatic (7045222) the correct vacuum port for distributor is the upper port on driver side of carb and it’s full vacuum at idle.
The only ported vacuum port is on lower throttle plate on passenger side of carb but it is modulated meaning the amount of vacuum tapers off as the throttle plates continue to open because it’s used for the EGR valve. I just went through this with Cliff Ruggles.
Old Apr 15, 2018 | 09:16 PM
lars's Avatar
lars
That's correct.
Lars
To Carb
