Alarm c3
Old Apr 23, 2018 | 08:34 AM
Marksog13's Avatar
Marksog13
3rd Gear
Default Alarm c3
My alarm popped out and is hanging down with wires attached, what keeps that secured and preventing that from happening..I assume a pin or bolt or something, thanks
Old Apr 23, 2018 | 08:44 AM
Barrist's Avatar
Barrist
I'm sure I "Borrowed" this from Willcox, Hope it helps.
Have a Great Day,
Bill
Old Apr 23, 2018 | 09:36 AM
Marksog13's Avatar
Marksog13
3rd Gear
Default Alarm
Yes I doesnow I know what I'm looking at and for...quick question on chrome hood inserts for Lt1 hood..do they get screwed in and are those screws visible from the outside or is there a rubber seal that covers them...haven't not been able to find any real good up close photos...thanks for the help
Old Apr 23, 2018 | 10:08 AM
Alan 71's Avatar
Alan 71
Hi M,
Welcome!
The chrome plated trim pieces have 'studs on their rear side.
The studs pass through holes in the hood and pal nuts (speed nuts) were used on the studs to hold the trim in place.
So no visible fasteners from the exterior side of the hood.
Regards,
Alan
From the Assembly Instruction Manual.
Old Apr 23, 2018 | 11:41 PM
marshal135's Avatar
marshal135
Veteran: Marine Corps
The spring clip in the above pic posted by Bill would prevent the lock assy from hanging
out of the rear panel by the wires. If I understand your ? correctly?
Marshal
Old Apr 24, 2018 | 06:58 PM
DUB's Avatar
DUB
Knowing what year you ahve would be a great help due to the alarm systems are different in regards to where the cut off switch is located.
So..with you asking about a LT-1 hood....i am assuming that your switch is like the one that has been posted.
So...it is possible that it may need a nut or more than likely it will be the same type of clip that is shown in the illustration.
DUB
To Alarm c3
