Air Breather Assembly
Old Apr 25, 2018 | 02:52 AM
spanky13's Avatar
spanky13
Default Air Breather Assembly
the original paint on the air breather assembly on a 1977 corvette a semi-gloss black or a gloss black
I assumed it was a semi-gloss black but I was told it was a gloss black
which is the correct paint color?
Old Apr 25, 2018 | 07:13 AM
Alan 71's Avatar
Alan 71
Hi S,
During the 68-72 model years the bases of both open and closed air cleaners were painted with gloss black.
There was no primer used and the paint was quickly and sparingly applied... so typically didn''t have a terrific gloss.
From the photos I see I believe the use of gloss black continued.
Regards,
Alan
Here's an example of the gloss on the air cleaner base from a 72 car.
Old Apr 25, 2018 | 09:14 AM
7T1vette's Avatar
7T1vette
Never seen a gloss black 68-72 air cleaner in my life.... except for those few who paint them gloss black; and they stick out like a sore thumb.
Do what you want, but it will only look right if it is semi-gloss black.
{NCRS folks can ignore my comments. I have no idea what your 'book' says is correct.}
P.S. I bought a barely-used '68 car in the early 1970's from the original owner; and the air cleaner was NOT gloss black. My un-restored (at the time) '71 car has a semi-gloss air cleaner with the original sticker still on the side. The paint was 40 years old at the time, so it certainly did not look like 'new'. But the sheen on that air cleaner was exactly the same as the other semi-gloss black parts in the engine compartment.
Old Apr 27, 2018 | 04:10 AM
spanky13's Avatar
spanky13
Thanks for the help, very helpful
To Air Breather Assembly
