Good Day - looking for best way to repair these without taking front bumper off and buying a new one. The entire bumper is mint except for this which happened today, coming off ramps. All options especially fixing it myself would be appreciated. Thank you
I'm sorry I can't help you with the damaged bumper.
However, to prevent this in the future, you may want longer ramps. When I don't put the car up on the Qwik-Lift, I use 2-part 56" Race Ramps for quick fixes. They make even longer ones, too. The site will show you how to measure the approach angle and determine which size you need. 56" worked for my 80 (shown with the 79).
[QUOTE=Bikespace;1597278595]I'm sorry I can't help you with the damaged bumper.
However, to prevent this in the future, you may want longer ramps. When I don't put the car up on the Qwik-Lift, I use 2-part 56" Race Ramps for quick fixes. They make even longer ones, too. The site will show you how to measure the approach angle and determine which size you need. 56" worked for my 80. [/QUOTE
I have an 1982 also and have had damage to my front end numerous times. The best solution is to take it to an experienced body shop and have them repair it. You do not need to take off the front bumper. All you need to do is have him repair it and then blend with paint the repaired area into enough of the surrounding good paint. I have had my auto body guy due it numerous times and it came out great!!! The secret is to get a hold of an experienced auto body shop who will work with you. Good Luck
If you are on a budget, you can use your regular ramps, go buy a 8' 2x8, cut it in half and use that to change your getting up and down the ramps. Been using mine for many years for both my c3 and c4 corvette.
