Shifter console- 4 screws
Old Oct 27, 2018 | 06:05 PM
BarretHC1's Avatar
BarretHC1
Default Shifter console- 4 screws
Hello to all,
I am putting my shifter console back in after replacing the boot, and obviously the screws are stripped. Does anyone know of any place that specifically sells screws that are a bit larger for this general purpose?
Old Oct 27, 2018 | 06:58 PM
BarretHC1's Avatar
BarretHC1
For anyone else in the same predicament. As long as your tabs are in decent shape, Willcox sells a screw and snap bracket that will suffice. Just ordered. FYI!
Old Oct 28, 2018 | 02:13 AM
TimAT's Avatar
TimAT
You can hunt up j-nuts at most big box hardware stores so upu can use your original screws too. Also could be called speednuts.
Old Oct 29, 2018 | 10:47 AM
7T1vette's Avatar
7T1vette
Could also epoxy some metal tabs to what's left of the original fiberglass tabs. Drill new holes and use J-nuts for the original screws.
Using larger screws is not a particularly good idea. Larger screws have larger heads which would stick up above the surface.
To Shifter console- 4 screws
