Unkown part
Old Nov 7, 2018 | 02:48 PM
fastimes's Avatar
fastimes
St. Jude Donor '19-'20-'21-'22
Default Unkown part
Okay, here come the silly questions . . .
Found this in my glove box. Plastic part with matching piece of insulation.
Anyone know what it is and where it goes?
Old Nov 7, 2018 | 03:02 PM
kansas123's Avatar
kansas123
It goes between the steering column floor bracket and the floorboard. The holes line up with the two bolts that hold the bracket to the floor and the cutout encircles half of the column and I believe the small cutouts accept the two rubber plugs that hold or help hold the carpet down.
Old Nov 7, 2018 | 03:29 PM
fastimes's Avatar
fastimes
Thank you!
Old Jan 14, 2019 | 08:33 PM
fastimes's Avatar
fastimes
I now this is an old thread, but does anyone have a photo of this part installed?
Thank you!
Old Jan 14, 2019 | 08:57 PM
Mooser's Avatar
Mooser
Probably won't help but it's upside down in your picture there.
Two plugs holding the thin in are tucked under the edge of the fuse panel and over towards the go pedal
The two slots in it just clear the two plugs holding the carpet
M
Old Jan 14, 2019 | 09:02 PM
Mooser's Avatar
Mooser
You can half see it in the background of this picture, the plug over on the right is one of the two really holding it
Old Jan 15, 2019 | 01:02 AM
fastimes's Avatar
fastimes
Thanks Mooser, that helps a lot.
Old Jan 16, 2019 | 12:32 PM
fastimes's Avatar
fastimes
Is this held in place with the same type plugs that hold the carpet down?
Old Jan 16, 2019 | 12:38 PM
Mooser's Avatar
Mooser
Yups
3868790 (but I used some that were longer as I've added sound deadener etc )
M
Old Jan 17, 2019 | 12:51 AM
fastimes's Avatar
fastimes
Darn if I can find that part in my AIM.
Old Jan 17, 2019 | 06:56 AM
Mooser's Avatar
Mooser
For my 72 AIM
M72
ASM 1
D9
Dash mat, insulators & splash shields
Old Jan 17, 2019 | 08:00 AM
fastimes's Avatar
fastimes
Thanks Mooser!
Old Feb 8, 2019 | 10:54 PM
fastimes's Avatar
fastimes
Yups
M
So I bought the rubber plugs to install this piece. Holy Cow! is there a trick to getting these bad boys in? I tried some wd-40, used a torx driver to try and push them in. No go!
I tore through 3 of them (good thing I bought a few extra). Going to hold off to see if anyone has any suggestions. I don't want to destroy all of them.
Old Feb 9, 2019 | 08:43 AM
Mooser's Avatar
Mooser
I've now got an old screwdriver with the tip cut off and rounded over a little (edges smoothed but still fairly flat on the end). A little grease (silicone spray or whatever I find first) and work the plug into the carpet sort of moving the screwdriver around in a circle rather than trying to straight push it in. That said, anywhere I can reach the back side of the plug from under the car I'll try grabbing the end with some pliers and pulling it the rest of the way
https://www.corvetteforum.com/forums...fasteners.html
https://www.corvetteforum.com/forums...pet-plugs.html
M
Old Feb 9, 2019 | 10:22 AM
fastimes's Avatar
fastimes
M
Thanks Mooser! So I'm not the only one to struggle with these things
I'll try and fabricate a tool as you did. Hopefully that will work. No wonder I found that trim piece laying in the glove box!
Old Feb 15, 2019 | 09:56 PM
Eliredandblack's Avatar
Eliredandblack
I used a large Allen Wrench that has is flat on the same plugs for the rear vertical panel next to the courtesy light on my 73 vert. When I replaced the carpet on my car, I never saw that plate, I will assume that Bubba decided it was an unnecessary part.
Old Feb 15, 2019 | 11:04 PM
fastimes's Avatar
fastimes
Thanks Eliredandblack. You're right about Bubba. If you don't know how to get it back in place, just leave it out!
I used a cheapy screwdriver, cut the tip off, and ground the end blunt. It worked for three of the plugs. The fourth, closest to the console, is a struggle. I was cursing so loud in the garage, I'm sure my neighbors think I'm a domestic abuser. It's been a few days, and I have one good plug left. I'll reattempt after a nice cup of morning coffee.
To Unkown part
