Bad Aftermarket or Repo Parts
Location: About 1100 miles from where I call home. Blue lives matter.
Received 5,331 Likes
Example: I broke a pull strap off a rear compartment door on my ‘69. Easy fix, easy replacement. cheap item, they are all the same, right? Oh, noooo.
I ordered from one of the major vendors and was horrified by the piece of garbage they sent. The size of the leather, width and depth was half. It was made out of a plasticy vinyl. The replacement screw was a flat head screwdriver thingie from the hardware store. Photos of the prior part (also a repro and very close to original) side by side with this thing was laughable.
Turned out, it was very difficult to buy this part. Many vendors didn’t picture the part in their listings, or it was so small you couldn’t tell the detail. After a lot of research, I took a gamble on another and it was a good one. But seriously, who sees that coming?
To the original vendors credit, I sent them a note, not just about the item and transaction, but wondering if was worth selling garbage just to get a price $2 lower and then getting them returned? They were very responsive, agreed, apologized and refunded everything including all shipping.
Hey Guys,
Additional information. Read this for your entertainment.
https://www.corvetteforum.com/forums...epo-parts.html
Darrell Quickdraw Glanton
man. like i get what you are trying to get at. stuff aint what it use to be, but youre getting replacements not nos factory pieces.
but like i said, maybe your car is jacked up or you just have bad luck.
you just seem to be bashing with no detailed information as to what is wrong. just that they are bad. pretty baseless
Maybe take instruction and see if your wipers are grounded right, (common problem wiring where people burn up there motors with bad ground).
probably frying all your other crap beacuse something is wrong/hot. also looks like you ordered the wrong drive shaft coupler, doesnt mean its bad. things need to be broken in too.
latch aint gonna work like a 40 year old broken in and well adjusted unit.
I had a problem recovering my seats on my 75. The seat foam is too big for the covers or the covers are not made large enough to cover the new foam. After a month of phone calls to the supplier they sent me everything new again. Same problem.
send them to an upholstery shop they know what to do. you have to "shrink" the foam by compression it,, or putting your body/arm on it to squish it at the same time you apply the cover. also you use a thin plastic sheet/or bag and place it over the foam to help the cover fabric slip over the foam easier and not get caught. hope this helps.
Bad aftermarket parts
that is NOT a problem. that is how they are suppose to be. Otherwise the covers would be loose and look wrinkly.
https://www.corvetteforum.com/forums...-corvette.html
https://www.corvetteforum.com/forums...r-windows.html
Hey Guys,
Corvette America's door latchs are beyond terrible. I installed them new on my corvette. The lock and unlock mechanism is so hard to use, none of my lock features work. The door latch is impossible to unlock/lock with a key it is so hard. The actuator cannot overcome the friction required to work properly. And even the manual lock, I had to use a pair of pliers to actuation unlock and lock. Terrible product. Now I have to dissassemble my whole door(s) and put on a new latch after just doing it. I have ordered two from Zip Corvette and we'll see how those work. I will keep you posted.
probably ask who manufactures them. probably come from the same place.
You seem like the type of fella who should be looking for nos gm or good used pieces, instead of the aftermarket junk you will never be satisfied with.
I would try to find a good used set. they are usually bulletproof as long as the car wasnt sitting in the woods somewhere with the doors/windows open for 20 years.
ddglanton (01-15-2019)
Platinum Supporting Vendor
ddglanton
Your know Sir, since you said I couldn't be more wrong, then obviously I have no more to say to you. You obviously do not want to listen, but you have your mind made up. I get your point. No product improvement. No listening to the Customer. No Continuous improvement plan in place. It's do what you always have done. And that is OK. Let's let the readers of this forum decide. Am I always right about things no. But at least I am willing to listen and willing to learn and make adjustments. Of course. Unlike suppliers.
Justin
The following 2 users liked this post by Zip Corvettes:
bmans vette (01-21-2019),
NONN37 (01-14-2019)
The headlight switch's were fixed and I have not had an issue with those in awhile.
NONN37 (01-14-2019)
#34
Hey Guys,
NONN37 (01-14-2019)
#35
Hey Guys,
#37
I wrote 2 letters to the 4 or 5 vendors that I dealt with directly (The same, and additional vendors were used by the shop doing the actual work.) The first garnered a phone call and a letter from one vendor. The second an email from another. Both received high marks from me in my original letter. The second letter was an admission of our mistake with respect to an item from one vendor, but I shared that letter with all the original recipients so that all would know I'm happy to admit my errors. That particular vendor has not, yet, responded. The vendor who cost me the most has not offered to accept the item for a refund, nor have they put the advisory statement on their page that they said they would.
As for wiper switches, I think the third one worked. I don't know the vendor for the brake booster, which failed some months after getting the car on the road. That vendor took responsibility and supplied a replacement.
#38
Dr. Detroit
Received 3,892 Likes
I got a pair of black A-pillar trim pieces for my 72' and they flat out do not come close to fitting. $160 a pair and they are laying under the bench. Quite a disappointment.....I might be able to tweak them but got better things to do. They came from Corvette Central.
I am not that upset really because I should have sent them back and didn't, but they barely look like they were designed for a C3 they fit so poorly........I just wonder if anyone tries this stuff out in a prototype or dry run before they sell it.
Jebby
Jebby
#40
