Restoring parts....some help
I am going to be tearing down the rear end to replace some bushing, bearings, and restore some parts. I wanted to know what people typical use for restoration. Do I need to buy chemicals or just a few tools. For example, i am going to clean up some metal parts, like the leaf springs. I will need to remove all the rust and repaint them. Should I get an angle grinder (I see a lot of videos using it, but I was unsure if i really needed that)? I already have a bench grinder with a brass brush. Do I need to get a steel one of car parts?
Thanks for the suggestions.
I highly recommend the used, vintage Rockwell Air Drills that are on Ebay (pistol grip style). They last forever, and of course, you should always oil them, with air tool oil, before use. You should also have a die grinder, like an Ingersoll Rand, style, that takes the steel coarse and fine brushes (in various sizes and styles). The die grinders are smaller and work good for tight spots. Hope this helps.
PS: Don't forget eye protection and gloves. When I buy Safety Glasses, I often just slit the plastic on the packaging, not quite all the way around, so I can store them inside the protective plastic and this keeps them clean and dust free and the cardboard packaging, makes it easy to store and find later on.
I didn't know they made different courses with steel brushes. I thought a steel brush is a steel brush. I guess I have seen the ones that has the wires twisted together into bunches. That seems pretty extreme for this though.
I sent my trailing arms out to be rebuilt. Otherwise, a drill with a wire wheel, and a wire wheel on a grinder, did the bulk of the work. I'm especially proud of the rear calipers, which really cleaned up with the wheel.
I went back and forth on the composite vs steel springs. End result was cost and i think I restore what is there. I don't replace if i don't have too, i prefer to fix if i can. In the event its all too much, i can always buy one. But they are pricey.
Mobird has a thread on the budget DIY route, which is worth looking up.
IF I need to have the rotors riveted on due to someone JUST HAS TO have them that way. Then I know how to index the rotor run-out prior to me riveting the rotors back on.
https://www.corvetteforum.com/forums...e-warning.html
DUB
Those things are nasty!! Safety googles, masks and thick clothing is a must. Those errant wires are dangerous
Here are some photos. This,
Did this after going through a heavy sweatshirt and heavy sweater,
So I cannot stress the safety factor.
Has anyone figured out a product that is clear but can go over some rust since it is almost impossible to get every spec of rust out and I like to keep the bear metal parts unpainted but coated to keep them from rerusting? I have some rust coming through some of the cleaned up and clear coated components. Here are some before and after of my work but within 4 months I can see some rust coming through. Ike
I also will try to steer you to Bairs for your trailing arm work. Extremely good at what they do and nice to work with as well.
Good luck,
RM
The proprietary water-base formula penetrates into voids on the metal surface and dissolves rust and oxidation through chemical action. Small rust-inhibiting crystals are formed and become integral with the surface molecules of the metal to resist future rusting.
I hope mine comes out looking that good.
MickP, do you have any other products. I wouldn't want to have to reclean all my parts every 12 months.
https://www.lpslabs.com/product-details/612
DUB
Mick I tried that product or something similar a few weeks ago, but I was walking out the door when I tried it. It left a odd milky coating to the metal, not the finish I was hoping for. I wanted to try to capture that cast, raw metal look without painting and prevent it from re rusting. I tried a few clear coats but I did not pay enough attention to which went were. I am seeing rust come back on the lower shock supports and the connecting rods. I wonder if any of the clear coats, enamel, varnish, lacquer etc are better then others?
Thanks Ike
