Weird electrical/ starting problem- please help
But also, here you go again with the wording. I took your term on RUN for the key position as the spot where the key comes back after letting off of it to start....? But then you say no start in RUN. See why it's confusing?
Last night I changed out 2 questionable looking connectors- one at the starter and one at the coil. They were both slightly loose and poorly crimped.
Today I went out and got an inline spark tester. Spark is good, and it actually fired up- for about 2 seconds, then wouldn't restart.
I inspected the fuel system, and noticed a small leak at the fuel pump, and could not find a fuel filter anywhere.
I have a Holley 750 DP, 4150. I believe there should be a fuel filter between the pump and the carb, right? (My engine building did a great job on the engine itself, but seems like he threw it all back together in a hurry.)
I can see fuel entering the bowl when pulling the accelerator by hand, but the bowls of the carb are fairly dirty, so I guess I may need a carb rebuild. I'll probably end up starting another thread with questions about the carb and fuel system because I don't know much about it unfortunately. Thanks everyone for you help. At least I don't have to pull the steering wheel and drop the column again lol.
Yes, you need a fuel filter! Mine is just a rubber line, take that into an auto parts to get one that matches the size of hose. I would try letting the entire carb sit in a gallon of carb cleaner that you can get at walmart. High fumes from that stuff, keep out in garage and away from door that goes into your house, otherwise the stink will be in the house for awhile. Let it sit for a few hours or overnight, blow out with air gun(wear goggles), slap it on with new filter and see what happens. If crappy still, then perhaps a rebuild is in order. Be sure to use hose clamps with new filter, also inspect the rubber fuel lines, may be time to replace, the hose is cheap.
I wish I could have been there to see your face when it fired up......and then died. Haha, sorry I couldn't resist!
I like the idea of soaking overnight So that's safe and won't damage the internals?
I ordered the molded fuel supply hoses and will pick up some fuel injection hose for between the pump and carb. Will definitely add a filter in that line.
Thanks for the help.
Edit: yes I knew I needed a fuel filter lol, just wasn't sure where in the system it's supposed to be placed.
Just make sure the hoses are for fuel.
Filter goes a few inches from carb inlet. Short rubber hose that you will make goes in between
