How do you paint headers?
Old May 16, 2020 | 08:24 PM
Rob Via's Avatar
Rob Via
Default How do you paint headers?
I was watching a show and saw a set of headers painted black. I would like to do that to mine. Do I just use high temp paint? I would expect the headers to get over 500 degrees and high temp paint to fail. But, I don't really know. Do I take them and get them powder coated? Hoping I can do it myself, but don't want it to look like crap after 100 miles.
Thanks in advance.
Old May 16, 2020 | 08:57 PM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
No powder coating , it's like plastic.
In auto parts stores they have header paint that is good for 1200 f degrees but you have to get the surface really clean. The best bet is to look up header ceramic. Coatings. You may have someone local that does it. Jet Hot will do it if you send them in but can cost $400 plus dollars depending on length. If you search ceramic header coatings there was a thread these last 2 weeks about this subject t
Old May 17, 2020 | 02:02 PM
7T1vette's Avatar
7T1vette
VHT spray paint (very high temperature) has colors that are good up to 1200*F or so. Seymour spray paint has colors going up to 2000*F. Both of these brands actually get their FULL cure from manifold heating with an operating engine.
Prep is to shot/bead blast the parts; wipe/wash them down with a solvent which does not leave any residue; then shoot two covering coats of paint on the items and allow them to air dry. Assemble them to the engine carefully to prevent damage/scratches, as paint has NOT fully cured. Run the engine at normal operating temps and then at 'working' temps to fully cure the paint. Seymour is a REALLY smoky, stinky curing paint. But it is GREAT STUFF once it is cured (4-6 hours of running time).
Old May 18, 2020 | 07:10 AM
derekderek's Avatar
derekderek
gas grill paint works good too. black only though.
Old May 18, 2020 | 07:49 AM
Rob Via's Avatar
Rob Via
I don't have a bead blaster. Is that something you find a local shop to do? How much should that cost?
Old May 18, 2020 | 08:45 AM
DaGuvner's Avatar
DaGuvner
After blasting I used the VHT primer and top coat and cured by baking in the kitchen oven.
Old May 18, 2020 | 01:26 PM
Rob Via's Avatar
Rob Via
What grit would you use to bead blast the headers? I have a friend that has the tools, but I have to buy the media.
DaGuvner - do you have a bigger picture of that hood emblem in your avatar? Where did you get it? I have been thinking about what I should do on mine. I was thinking about a vinyl sticker that says "LS-383", but that one looks pretty cool.
Old May 18, 2020 | 02:35 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
Cerakote ceramic paint does a really nice job and you don't have to bake it. You do have to clean them good and blasting is preferred. it is the system I used on mine about 5-6 years ago and still looks new.
Cerakote Link
Old May 18, 2020 | 06:06 PM
Stev-o's Avatar
Stev-o
I would bring them to a shop for blasting and ceramic coating. That will be the best, longest lasting finish you can get.
Old May 18, 2020 | 07:54 PM
7T1vette's Avatar
7T1vette
Ceramic coated = C-note$ Nice, if you can afford it.
VHT or Seymour spray paints = less than $20
You don't have to bead blast it to get them clean. That's just the easiest/best way to make sure the surface is free of corrosion, etc. You could either wire-brush them or [if smooth surface] use fine steel wool. Then use a no-residue solvent and shoot away.
Old May 19, 2020 | 08:17 AM
Rob Via's Avatar
Rob Via
I see 80 grit glass media for $40 and $25 of the VHT paint is probably enough to get it done. It's not a show car, I just want it to look better. I think that's the route I will take.
Any suggestions of a brand of no-residue solvent? That's not something I have laying around the garage right now, so I will have to buy that.
Old May 19, 2020 | 11:43 AM
7T1vette's Avatar
7T1vette
I use Lacquer Thinner. But leave a window open or do it outside to save what 'good' brain cells you still have...
Old May 19, 2020 | 12:58 PM
Rob Via's Avatar
Rob Via
If you see my bourbon collection, you will know I don't have many of those left.
Old May 19, 2020 | 01:53 PM
jackson's Avatar
jackson
If you like black ... wallyworld has a buttload of their brand of black aerosol for a buck ... a touch-up every now & then
Old May 19, 2020 | 04:50 PM
7T1vette's Avatar
7T1vette
If you do it properly with good paint product, you will NEVER require a touch-up.
Old May 19, 2020 | 06:13 PM
NewbVetteGuy's Avatar
NewbVetteGuy
Just pay a sandblasting place to bead blast it.
Then do the VHT paint; the instructions tell you to heat it up to a certain lower temperature for 20 minutes, then let it cool for 20, then heat it to a higher temp for 30 minutes, then cool for 30 min. Then heat it to an even higher temp for 40 minutes then let it cool for 40 minutes to cure it.
-It also says it puts off toxic fumes so don't do it in your house, but....
Adam
Old May 20, 2020 | 08:11 AM
DaGuvner's Avatar
DaGuvner
I found the "383 Stroker" emblem on ebay. Here's the link: https://www.ebay.com/itm/383-Stroker...ss!20876!US!-1
It is made of molded plastic and had been chromed in areas, 4 inches by 1 inch and fit perfectly on the side rise of my stock 76 hood.
I had my body shop shoot them with a high quality clear coat for uv protection. Also I think (from my memory) I had purchased a high quality 3M body molding adhesive roll, applied to the back, and trimmed to fit with an exact-o knife.
Old May 20, 2020 | 06:29 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Xylene, if you can get it in your state.
Old May 20, 2020 | 11:20 PM
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
I used aluminum colored Bill Hirsch Manifold paint 30 years ago on my LT-1 headers. Good for 2000 degrees.
Never touched them up at all, still looked great.
https://www.hirschauto.com/EXHAUST-A...nfo/EMPT-PINT/
Must be similar to the Seymour mentioned above, lots of fumes for a few hours til it final cured.
To How do you paint headers?
