octane headlights
Old May 21, 2020 | 05:10 PM
jkippin's Avatar
jkippin
Default octane headlights
ok so recently i saw a post on Octane Headlights. How many have used these and are they just plug and play as stated? I have read some need to upgrade the wiring and others have had to cut the buckets to get the lights to fit. what about the retainer rings fitting around the lights to the buckets,
Figured I would start a new post instead of hi- jacking the existing one.
John
Old May 21, 2020 | 07:02 PM
DonnieP73's Avatar
DonnieP73
These are the ones that I put on my 73. They were a perfect fit and didn't have to change anything.
The retaining rings fit just like the original lights that I replaced. They work high beam and low beam as they should.
It was just like replacing the seal beam ones. I am happy with them so far.
https://www.octanelighting.com/5-34-...033-034-2.html
Donnie
Old May 21, 2020 | 08:40 PM
jkippin's Avatar
jkippin
cool thank you
I ordered a set tonight so I was just looking to see if I would need to prepare for any hidden problems. Hopefully I will only be out of work for the next few months waiting for a new contract. While I have time off I hope to spend time with the Vette and doing some around the house projects.
Old May 21, 2020 | 09:10 PM
C3 Stroker's Avatar
C3 Stroker
They are plug and play depending on which p/n # you get. The ones with the narrow fans on the rear fit in place like stock. The brighter ones with the slightly larger cooling fans need about a 1/16" clearanced on the access hole behind the bucket in a '69. (Or you can disassemble the cable and feed it through). For me, it was easier to ream the hole with my Roto Tool......took about 5 minutes. My thread....https://www.corvetteforum.com/forums...installed.html
Old May 21, 2020 | 09:20 PM
jkippin's Avatar
jkippin
hopefully I did order the correct ones
tem specifics
Condition: New Brand:
OCTANE LIGHTING
Bulbs Included: Yes Bulb Type: LED 18/24 Watts Assembly Type: Composite Manufacturer Part Number:
5.75-004-005-METAL-BULBS-HID-6000k-3RD-GEN-ST-1
Bulb Size: H4 (9003) Interchange Part Number: H5001 H5006 4000 5001 5-3/4 INCH 5.75 Round 5.75" 146 mm PAR 46 Lens Color: Stock Glass Other Part Number: 4000 5001 Housing Color: Chrome Placement on Vehicle: Front, Left, Right Surface Finish: Stock Glass Lens / Metal Backside Warranty: 90 Days Superseded Part Number: 4000 5001 Bundle Listing: Yes MPN:
Fitment Type: Performance/Custom UPC:
664979139347
ISBN:
Does not apply
Old May 24, 2020 | 08:41 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Is it going to make your car faster???
My Dad always asked me that growing up when I added something to my old Mustang..LOL
Im tagging along because my current option isnt that great
Old May 26, 2020 | 01:25 PM
mike6896's Avatar
mike6896
6th Gear
HI, I just ordered for my 74 and they were super easy to install. Plug and play all the way and they look great. Good luck with yours.
Old May 26, 2020 | 01:30 PM
jkippin's Avatar
jkippin
Rescue- it just might.....and yeah that blight bar you have is blinding me every time I pass you. LOL
Mike6896 That's good news thank you. Mine should be here next Monday unless Rescue steals them off the porch while I'm not looking.
Old May 26, 2020 | 04:32 PM
Rescue Rogers
Road trip. I gotta pick up that drive shaft from Gilbert's tomorrow too
Old May 31, 2020 | 08:23 PM
jkippin's Avatar
jkippin
Well I just received the headlights and should be putting them in this week if I get time They look good and are as advertised. The lenses are glass and the whole reflector is made from metal. The LED bulbs do have a fan built into them and have a ballast resistor to I believe that is what the Square black box is. Two of the lights have all three of the wires in the plug socket and the others have a third wire disconnected but has a spot in the plug if you want to use it. I suppose this would be so all four headlights could be used at the same time for high and low beams.
You possibly could drill a hole for fiber optics but I'm not sure if it will chip the reflector on the inside from the drill going through. Here is a photo of them
Old Jun 1, 2020 | 08:33 AM
KenSny's Avatar
KenSny
I'm really interested in this. If you can post a couple of installation pics or things to watch out for that would be great.
I've read that they are take-out-old and put-in-new. Is it really that simple?
Would be nice to get rid of these old sealed beams that don't do the job anymore.
Old Jun 1, 2020 | 10:47 AM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Those look like decent units with glass lenses and metal reflector housings. They look exactly like the AutoPal units I used to
make my LED halo headlights. They are probably made in the same factory in China/India/wherever!!
Old Jun 1, 2020 | 04:09 PM
jkippin's Avatar
jkippin
yup probably are IDK but they say Made in USA
Old Jun 1, 2020 | 04:25 PM
jkippin's Avatar
jkippin
These are installed in my 1976 Corvette so I don't know if the earlier years (like 68) will be the same.
Ok so I installed one set of headlights and they fit as advertised as OEM. I had to do absolutely NO modifications. When I pulled them out of the box I was not sure because of the way the mounts are on the side of the lights. but the retainers fit perfect with no modifications or longer screws.
These look best to me because they look like a regular replacement light.
Showing retaining ring fit on the low beam
You can see my old inner high beam bulbs. Aircraft landing lights
just low beams in better shot of high beam landing lights
The bulb does say made in China
Showing headlight protrusion from the bezel
Old Jun 11, 2020 | 07:23 AM
jokeitch's Avatar
jokeitch
Requesting pics of these on and pointed to a wall 20ft away at night. I wish to see the beam pattern
​​​​​​Although if it looks bad at first, make sure to rotate the LEDs in the housing, there's likely a sweet spot in their rotation for beam pattern
Old Jun 11, 2020 | 01:41 PM
KenSny's Avatar
KenSny
sounds good. Should fit my 75 then.
Yes, beam pattern is something I'd like to see also.
Old Jun 11, 2020 | 02:11 PM
jkippin's Avatar
jkippin
I will get a few pictures when I get a chance. I can tell you that the lights are very bright with a definitive cut off on the beams.
The cut off must be just right because I do not get on coming drivers to flash High Beams to me.
Like all LED these are polarity sensitive so if they don't work flip the plug. The high beams have an extra wire so they can be set up to run on both High and low beam instead of just high beam.
To octane headlights
Old Jun 17, 2020 | 07:57 PM
jokeitch's Avatar
jokeitch
interesting, does that mean you could run all four headlights at once in a low beam mode, then also have a high beam mode which just makes them brighter?
also, really excited to see that beam pattern
Old Jun 17, 2020 | 08:16 PM
jkippin's Avatar
jkippin
Sorry ive been extremely busy lately trying to get home projects done that have gone by the wayside for far too long. Hoping I can get the beam patterns this weekend.
Yes you can run all four lights at once low beam and then on high. I opted to just keep them stock.
Old Jun 17, 2020 | 08:27 PM
KenSny's Avatar
KenSny
Looking forward to the beam pattern. Especially with all 4 on low beam at the same time.
Just wondering how annoying that would be to the car in front of me.
