Inner door panel upholstery
Old Aug 2, 2020 | 03:20 PM
Ktruff's Avatar
Ktruff
Default Inner door panel upholstery
Has anyone here reupholstered their own inner door panels? I don’t care about originality, and can’t see spending nearly a grand for new ones. Any info would be appreciated!
Old Aug 2, 2020 | 04:54 PM
HeadsU.P.'s Avatar
HeadsU.P.
I hear ya about the cost. One option if your panels are not worthy. Check EBay for used ones. Pay attention to correct yr and P.W. or not. They can be painted to match.
And if the armrest is really wonky, somebody sells a armrest cover in several colors that looks pretty factory.
Old Aug 2, 2020 | 05:05 PM
7T1vette's Avatar
7T1vette
If the basic shell of your door panels are in good shape, re-upholstery could be easily done by you (if you have those skills) or by an auto upholstery shop. If you are not locked into the 'original' scheme, that would be a nice route to go for updating your interior.
Old Aug 2, 2020 | 05:21 PM
SwampeastMike's Avatar
SwampeastMike
I'll be recovering the door panels in my '79 green cloth interior in the coming weeks. Found original fabric and vinyl and will do my best to make them look completely original. Will take photos along the way and post progress.
As with any upholstery work you need a strong sewing machine, preferably with a true walking foot. That said I'll be using an old Singer 401 with pseudo walking foot accessory. Such worked for repairs I previously made to the seats and while not a true commercial upholstery machine it does well for small amounts of such work.
Old Aug 2, 2020 | 05:42 PM
Ktruff's Avatar
Ktruff
I have looked in other Vette groups and eBay and Craigslist and there are used ones there, but again, at $300-400 plus shipping. Not worth it to me. Anything less money are trash and I’m back in the same boat. So looks like I will give it a try. The backings are good shape, but the material covering them are dried out, worn out, split and just nasty. I will post pics of my progress.
Old Aug 2, 2020 | 06:26 PM
SwampeastMike
I know you aren't going for original appearance but you do have to follow the basic pattern of the original lest you break the backing by trying to stretch things... Such patterns are not available so you must make your own by carefully taking apart the original. Also know that materials suitable for auto upholstery are expensive and intentionally hard to find.
Please keep these things in mind before you start spending money in hope of saving it
Old Aug 2, 2020 | 07:07 PM
Ktruff's Avatar
Ktruff
Well, I have 2 sets of panels to work with and have gotten enough material to cover both doors for less than fifty bucks. So even if it doesn’t work out, it won’t break the bank.
Old Aug 2, 2020 | 07:14 PM
interpon's Avatar
interpon
How bad are they?
patch up tears etc..can of dye your out 50 bucks
Old Aug 2, 2020 | 07:25 PM
Ktruff's Avatar
Ktruff
The basic shells are good but the vinyl covers are toast.
Old Aug 3, 2020 | 01:28 AM
7T1vette's Avatar
7T1vette
I suggest that you prep the existing panel covering before putting new material over it. Trim off all loose ends that stick up. Then, use some polyester body filler to fill in for missing material where you removed it, and also fill in any cracks. What you want is a surface without gaps, cracks, pits, so that the new material will lay smooth on the existing surface. Otherwise, any surface defects will be transferred to the surface of the new material as low areas. Patch it up first....
Old Aug 3, 2020 | 04:52 AM
wendellp601's Avatar
wendellp601
Here's a thread from a couple of years ago in which a user reskinned his door panels.
https://www.corvetteforum.com/forums...n-restore.html
To Inner door panel upholstery
