Help!!!
if it was running and then died on the side of the road it indicates one problem.
Now from the time it stopped running what was the next scenario? did you have Battery power or was the battery dead?
* If dead indicates it was running off the battery and you have charging system problem - whole bunch of things here to check
* If you still had power it indicates an electrical short someplace - Other things to check
* if motor made funny noises and stopped running- well that's not good.
Do you or a friend have a multimeter?
Do you have a way of checking for voltage at the solenoid?
You should have a constant 12V. On the solenoid should also be an "I" terminal for ignition that comes from the keyed 12v source when the key is in the run position.
The other is "S" for start going back to a keyed 12V keyed source.
You can also check your grounds at the starter I would check those first
Have you looked at the fusible links at all? any chance you can smell burnt wiring under the hood or under the dash when this happened?
Before spending any money lets check a few things here
sounds like it may have a mechanical issue. will the engine turn over by hand? no - Your done -Yes - id pull the cap and spin the engine and check the rotor is spinning if so bring it to #1 TDC and static time the engine- If all looks good keep going if not trouble shoot why the rotor is out of sync.
Check for power at the solenoid. if its there install a push button (found at auto parts stores) and install it to the starter. this will bypass the safety features Make sure you are in park or put on Jackstands to keep rear tires off ground. if starter spins but will not engage its the solenoid. This happens alot in auto store starters from A-Z
I take it this is a "Side-Post" battery? Its tough to get a 100% connection with those crappy designs in tight quarters.
Remove the NEG cable first, clean thoroughly: cables terminal, batterys external pad and even the bolt. Leave it off to the side. Now do the POS side.
Take note how the cables bolt fits. Are some of the threads missing? Peel back some of the rubber around the terminal end and inspect. Do you feel that the cable is actually tightening down on the battery? Or is it the bolt just bottoming out with the terminal still loose?
Just went through this last summer. Switched to a 1 1/2" long bolt (same thread) nut & washer. First I run the bolt through the terminal and bottom out the bolt in the battery. Then tighten the nut / washer against the cable terminal. Super tight connection.
I now have bolt heads sticking out of the battery. What a great place to latch on with jumper cables!
Were you driving at the time? Any odd noises or anything catch your attention?
Prior to this, did it always crank just fine when the key was turned?
If an automatic trans, are you sure it's firmly in Park? Have you tried putting it in Neutral to start it?
mpicki: have you tried to turn the engine by hand with a breaker bar and socket attached to the crankshaft bolt at the lower front of the engine? (You'll likely need to remove spark plugs due to pressure in the cylinders laughing at your weak human strength
I'm leaning toward something in the ignition failing, but am by no means an electric-head. My first step would be to check whether the starter is seeing any voltage at its terminals and check to see if the starter is still functional. This shouldn't be an issue with it dying while running, but it's odd that there is no response when the key is turned.
Someone else correct me here: the starter and all of its electrical connections are completely out of the ignition system once the engine starts, right? Meaning you could disconnect all of the terminals and the engine would stay running?
mpicki,
You have to have the tools, the knowledge and a wiring schematic to correctly diagnose and repair your issue. Electrical gremlins are one of the hardest repairs of all the systems and can become quite complicated.
In my opinion, you would be farther ahead having your C3 flat-bedded to a respectable repair shop.
Good Luck
)mpicki,
Good Luck
Mpicki does have an alternative though, besides the repair shop route. He can learn every stinking thing about this generation of automobile and there is indeed a source for that, believe it or not. It's a book. It goes for really cheap on Ebay and it will describe in great detail and with color pictures, every single aspect of a 70's through early 80's automobile. How the ignition works, the transmission, the starting system, cooling system. Everything, even electrical. It even goes into what tools you should have and how to use them! It is the Readers Digest Complete Car Care Manual. I'm a military trained Motor Transport Mechanic (USMC, MOS 3521) and I've always been impressed and recommended this fine book. It is accurate and well done. Bring the book out to the garage, don't worry about getting it dirty, go ahead and explore your car, with your hands while you're going through, for example, the cooling system. Feel the hoses, look at where they go, note the belts, play with them, explore!
There's one on Ebay for the princely price of $8.99 to $15. Just use the title as a search in Ebay. Secondly, order the GM Service Manual for your year Corvette. Certain years used the 1974 as a basis and then printed appendices. I forget which year, after that, that GM printed a new complete manual (feel free to jump in here, forum members, mine is a '74). Finally start making friends with the car crowd, the old guys who work on these things. You may get advice of varying qualities, just like you did here. If you can find someone knowledgeable to come look at it, your miles ahead.
To other forum members, we've got to find a way to deal with the newbies. A permanent sticky to refer to, would be great. "So you've just purchased a C3 Corvette and now it has problems, what to do?".
maybe my start when bad?
