Ignition won’t work
Old Aug 22, 2021 | 12:06 PM
Marco Romero's Avatar
Marco Romero
Default Ignition won’t work
Hey there, I’m a new guy here. But I’m having trouble with my “81. When we bought the car we noticed that the owners before had rewired from the fuse box a push starter instead of the actual ignition. We replaced the starter switch last night but it still won’t turn over with the key. If anyone could help I would appreciate it.
Old Aug 22, 2021 | 07:05 PM
Mooser's Avatar
Mooser
Does the key still work for run and turning the car off? or is it electrically not doing anything anymore?
M
Old Aug 23, 2021 | 09:18 AM
Marco Romero
The key does work, I can turn the car off, and the only way I can turn it on is with a push start that the previous owner installed because of the ignition not working.
Old Aug 23, 2021 | 09:47 AM
7T1vette's Avatar
7T1vette
Likely something to do with the rod in the steering column. You might keep the push button, rather than to dive into the column. But, that's just one possibility.
P.S. You might call the P.O. and ask them....
Old Aug 23, 2021 | 11:44 AM
tankertoad89's Avatar
tankertoad89
Do you have a manual transmission or auto trans? 69-81 manual transmission cars have a "neutral safety switch" on the clutch pedal that prevents starter operation unless the clutch is fully depressed. Your description of the situation sounds like someone may have bypassed that switch for some reason.
Old Aug 23, 2021 | 12:24 PM
bluthundr's Avatar
bluthundr
I'm also betting it's something in the column. On my 76 the little plastic gear that actuates rod broke and Zip, Ecklers, etc don't have the part for this year. Once I took the column apart I found more broken parts including the big cast aluminum t/t ball - all in all it looks like around $400 to fix it in my case,so I would just keep the button.
Old Aug 23, 2021 | 01:19 PM
Mooser's Avatar
Mooser
By the sounds of it, since the key is doing everything else (off, run etc) the rack piece inside the column is probably ok and it's the actual switch on the column that is the problem
Not sure if the 81 was the same or similar to the older ones but there was a rod that ran down the top of the column that was moved by the key turning into the start position. The ignition switch was actually located on the column but down towards the middle/bottom of the column
Jim Shea papers might have some insight
http://jimshea.corvettefaq.com/
M
Old Aug 23, 2021 | 03:41 PM
7T1vette's Avatar
7T1vette
Definitely take Mooser up on calling Jim Shea. He worked at Saginaw Steering Division and knows those columns (and other 'stuff') inside and out.
Old Aug 23, 2021 | 05:25 PM
Marco Romero
its a manual transmission. So would that mean I would need to look into the safety switch and try to replace it?
Old Aug 23, 2021 | 05:49 PM
Mooser's Avatar
Mooser
Do you still need to push the clutch in when you use the starter button? I would think if it was the NSS they would have just bypassed that switch, not changed the key switch
M
Old Aug 23, 2021 | 07:51 PM
Marco Romero
M
No I don’t need to press the clutch to use the push button. When I looked into the push button I saw that it was wired from one of the ignition fuses to the engine. Almost as if they just have it with strait power to wherever it’s wired
Old Aug 23, 2021 | 08:03 PM
Mooser's Avatar
Mooser
Sounds like you need to spend some time with a test light and schematic to see what exactly they were trying to eliminate with that button.
Bypassing the NSS is a simple wire "jumper" so they went through a lot of work if that's all they were doing
There's a guy with free schematics for each year here
https://www.corvetteforum.com/forums...ispreloading=1
M
Old Aug 23, 2021 | 08:19 PM
Marco Romero
M
Alright I’ll look into that, thank you for the help with this topic, I don’t know if you would be able to help me with another problem I’m having. When I try to turn on my AC/Heater all I can hear is a clicking noise and that’s it.
Old Aug 23, 2021 | 08:32 PM
DC3's Avatar
DC3
Yep. Good chance these guys are onto something. One likely suspect is the ignition switch rack. GM cars were notorious for this part failing. When they do, they are no longer able to pull up on the rod that activates the ignition switch. They are readily available. I found one in the "Help" section of parts at an O'Reillys when mine failed. Here's one example but don't assume it fits your car - I just found it as an example of what could be broken inside the steering column:
https://www.amazon.com/Ignition-Actuator-Replacement-Various-Steering/dp/B007TY1MZM/ref=pd_sbs_6/141-3789166-2617463?pd_rd_w=oCtTr&pf_rd_p=755df9fc-1b62-4c8c-831e-91a7f8454d75&pf_rd_r=6P6XF5GS1KY2SVM3H1WG&pd_rd_r=83249c37-5d71-473f-981e-5160f0bbb841&pd_rd_wg=pfD8b&pd_rd_i=B007TY1MZM&psc=1 https://www.amazon.com/Ignition-Actuator-Replacement-Various-Steering/dp/B007TY1MZM/ref=pd_sbs_6/141-3789166-2617463?pd_rd_w=oCtTr&pf_rd_p=755df9fc-1b62-4c8c-831e-91a7f8454d75&pf_rd_r=6P6XF5GS1KY2SVM3H1WG&pd_rd_r=83249c37-5d71-473f-981e-5160f0bbb841&pd_rd_wg=pfD8b&pd_rd_i=B007TY1MZM&psc=1
As bluthundr mentioned, the plastic gear that moves this rack could also be part of the problem.
DC
Old Aug 23, 2021 | 09:53 PM
tankertoad89
Before tearing into the steering column and searching for some "unusual" cause, and if you have sufficient knowledge to wire up the neutral safety switch (NSS), I would go that route. The NSS may not even be there. If it isn't, I would STRONGLY suspect the previous owner made that mod for some inexplicable reason. What you describe sounds EXACTLY like how the system works (engine runs, key shuts off the engine, etc.) if the NSS is installed and you try to start it without pushing in the clutch. When you turn the key on, everything lights up exactly like it should, electrically powered gauges jump, but absolutely nothing happens with the starter when you go to start unless that NSS makes its connection when the clutch is pressed in.
Old Aug 29, 2021 | 11:51 AM
Marco Romero
Default Big thanks
Thank you to everyone that helped, I looked into it and replaced the ignition starter switch and now I can turn on the car with just the key. Thank you again to all that help!
To Ignition won’t work
