Octane
Old Sep 9, 2021 | 09:18 PM
1973bluevettee's Avatar
1973bluevettee
Default Octane
So the guy I bought my 73 from thought jt was a good idea to have 12:1 compression do I need to run 93 and octane booster? If so any suggestions
Old Sep 9, 2021 | 10:37 PM
68/70Vette's Avatar
68/70Vette
Pretty sure you will. Your engine should tell you if you have an octane problem. You'll hear the pinging. I had an engine with 11.5:1 compression. On 91 pump gas,the pinging would sound like the anvil chorus. I haven't used octane booster for a long time. As I recall, there were few brands that actually worked, the rest were useless. How did the seller handle the octane problem?
You can guy high octane racing gasoline in 5 gallon cans. 5 gallons in the tank with 15 gallons of pump gas will probably work. I think the last racing gas I bought was about $70 for 5 gallons. In the late 70's, I bought av gas at the local municipal airport in Jerry cans. Once I became a familiar customer, they would just pump the av gas right into my car. Highly illegal. I'm sure they wouldn't to this today.
Old Sep 9, 2021 | 10:41 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
I would ............. unless you the like the sound of marbles in a jar, farts, back fire pops, diesel run on & extra pinging
Old Sep 9, 2021 | 11:07 PM
7T1vette's Avatar
7T1vette
I'm not sure it will run well on 93 with that much compression. If it has aluminum cylinder heads, maybe. Otherwise, you'll need to add some AV-gas to the 93.
Old Sep 10, 2021 | 12:17 AM
1973bluevettee
its iron hump heads. Where can I find AV gas
Old Sep 10, 2021 | 07:35 AM
70s's Avatar
70s
An airport (AV=Aviation)
Old Sep 10, 2021 | 08:29 AM
1973bluevettee
well yeah I know it’s stands for that i never knew I could just go it the airport and buy jt fromt them even a big air port like ohair Chicago
Old Sep 10, 2021 | 08:40 AM
70s's Avatar
70s
Due to security most airports are locked down. But small ones (tiny ones...air strips) usually aren't and will be self serve. Or you can talk to someone at the airport to ask for help. Also, look up fuel dealers that specialize in race fuels (like VP Racing) because they will sell drums of various fuels. I've bought nitromethane and methanol by the 5 gallon drum from dealers and speed shops (neither are at an airport).
Old Sep 10, 2021 | 09:51 AM
7T1vette's Avatar
7T1vette
For the 'long haul' with your new car, you might want to consider going to some nice aluminum heads that will drop compression to 11:1. Then the engine will be 'happy with available 93 octane fuel and you won't have to go to extremes finding needed AV fuels. The car will also be more desirable to future buyers.
Old Sep 10, 2021 | 01:36 PM
1973bluevettee
-yeah I’m thinking of doing a engine rebuild and match some heads and a cam and bring the comp down I also don’t think he did a good job rebuilding it looks Liek some corners were cut😕
Old Sep 10, 2021 | 02:04 PM
REELAV8R's Avatar
REELAV8R
Drive it an elevation above 5000 ft and you won't have any problem with 93. Problem is they don't sell that octane at those altitudes at the pump.
How much trouble you have will depend a lot on the tune, how well the rebuild was done particularly quench and does it have flat top pistons or domes. How well it's kept cool. Where you get the intake air from, fresh air or underhood air. Without knowing these things it's gonna be trial and error.
Old Sep 10, 2021 | 03:09 PM
7T1vette's Avatar
7T1vette
Or you can just change the heads. Who needs an engine with 12:1 compression???
JMH's Avatar
JMH
7T1Vette has the right idea. Try aluminum heads. I too was stupid enough to build a 440 6-pack for my Challenger with 12.5 to 1 compression.
Tried EVERYTHING as far as octane boosters No luck. Has to have 110 octane racing fuel. Only thing that works for mine. Needless to say at 8 bucks a gallon she doesn't get out much any more.When I pull it to do a color change I'm going to put some sensible pistons back in it. That'll solve the problem.
Good luck.
Old Sep 10, 2021 | 03:54 PM
REELAV8R's Avatar
REELAV8R
How do you know for sure it is 12:1 CR? Do you know what cam is in it?
Why not do a compression test and see how much it blows.
Old Sep 10, 2021 | 06:10 PM
1973bluevettee
i did a compression test and each cylinder was 12:1
Old Sep 10, 2021 | 06:45 PM
L-46man's Avatar
L-46man
Avgas at 100 octane is available. In addition to the link below. Many of our larger lakes and the adjacent towns have high octane gas available for JET BOATS.
Stock up on 5 gallon Jerry cans.
https://cutteraviation.com/fbo-servi...t-fuel-prices/
Have you done any timing mapping? (IE knocking the timing back severely to see if you get detonation?)
Unkahal
Old Sep 10, 2021 | 07:48 PM
Buccaneer's Avatar
Buccaneer
From: Arizona - If you don’t know CFI, STOP proliferating the myths around it...
You basically have two choices...reduce the CR or use race gas. I wouldn't use AV gas. They sell 100 octane race gas here in AZ at the pump at some stations ( one is next to the track, Love's) and I throw a couple gallons in mine when at the track just to be safe when I play with the timing. 12:1 is pretty high for a street motor IMO. Are you just cruising or racing it? There are various ways to decrease the CR, the choice is yours.
To Octane
Old Sep 11, 2021 | 07:10 AM
cottoneg's Avatar
cottoneg
How do you determine the compression ratio by doing a compression test?
Anyway, I used to have a 11 to 1 stock motor. After two cleaning cuts on the heads and advancing the timing a bit I had issues. When I took the engine apart, there were chips around the rings from the detonation (or pre-detonation).
The next motor had 10.5 to 1. Aviation gas of sufficient octane may work. At 12 to 1, 93 octane may not cut it and you can do real damage to the engine.
Old Sep 11, 2021 | 12:04 PM
REELAV8R's Avatar
REELAV8R
a compression test gives you a reading in PSI, so how did you take that reading and determine CR?
Old Sep 11, 2021 | 12:34 PM
1973bluevettee
-yeah your right my fault my friend told me the wrong info I guess I don’t know my ratio he thought you could covert the psi to ratio but I did reaserch and that’s just not true
