Steering Column Questions
What is the proper name for this part and what is the part number(or link) for a kit for it? I'm finding the entire assembly instead of just the kit in my searching.
The old one, the retaining spring/clip broke when I removed it from the steering motor, as in the one that holds the metal bars inside the coupler
Reading the papers, it supposedly has more tilt positions and I've never seen the telescopic steering wheel on anything else. Also part of the blinker/wiper/dimmer lever. All of our old GM pickups only had a blinker and tilt on the column.
The most common issue on these columns were they would get 'sloppy' side-to-side like if you grabbed the steering wheel and moved it side-to-side. Either: 1) The 4 bolts that hold the cast aluminum tilt base would come loose ..real common. Or 2) The two pivot pins on each side of the column (esp the Rt side pin) would slightly wear out the cast aluminum tilt assembly boss (oversized pins are avail). Always check the 4 bolts for tightness first. Because it's kind of weak like that I would NEVER grab the steering wheel and use it as a handle to help get in/out of the tractor. Use other handles or you'll wear it or break the pivot pin area. Another issue you'd see back then was the bottom bushing or bearing on the column could get sloppy ..but not as common as the tilt issue. And of course, the key cylinders would wear out all the time. The column shift collar (yours doesn't have the shifter) would get gritty and 'loose' after a lot of use and dust esp in pickups. And of course, thieves would knock a hole in the bottom of the lower collar and lift up on the starter switch rod to steal a car ...that was a common weakness on those column (google it).
The reason your has a Briggs key is it's probably the same as a GM key. Lot of equipment used GM keys and columns. Jeep in the 80's used GM columns. My Jeep plow truck has a GM steering column in it. My skid steer uses a GM key. Lot of tractors and machinery use the GM-style key back then. Someone probably found yours at a Hardware store one time b/c the GM keys were out of stock and the Briggs key was the same and what they had on the shelf that would work. Things like that happen.
IDT there's anything super-special about that column other than the Corvette steering wheel, and it makes an interesting story to tell your tractor buddies. You should get a center button to put on the steering column and make up (or buy) a graphic with your tractor logo. That would be trick!
That 2-pot joint is basically a sliding pivot joint. Almost like a CV joint but 2 slides (and smaller). I think there's some outfit re-making them (Dorman?). Or go to a salvage yard and find a low-mile farm truck and that probably has a good one. If your tractor has a rag joint (flexible coupler) on it, they often get 'sloppy' even though you can't visibly see it. That can contribute to a lot of steering sloppiness. If your tractor has one. Maybe it doesn't. Repair kits are available.
I've had a lot of these steering columns completely apart over the yrs, even back in the 80's. If you don't have a 'lock plate hold-down tool' you should get one to work on them (OReilly's). Makes a hard job real easy.
Looking at the Briggs key assembly now and then looking at our 80s Ford pickup, I'm thinking that's probably where it came from or was meant for, styling wise. Either way now it's getting replaced as, from what I can tell, someone didn't have the key in all the way at one time or tried the wrong key and forced it, so the keys that came with it were jammed in there. Even after taking it apart, I don't know if they are the correct keys or if they are so screwed up that the key cylinder is basically shot.
with this setup, you can't really hang onto the wheel to get in, as to reach in from outside you'd about have to fall onto the seat. The cab is roughly 6' wide for reference. (Pictured is the "little" one at 400 horsepower with a Detroit Diesel 8v92 Turbo that's locked up).
As for the "theives stealing cars" way, that's how we start a few vehicles as the rod or something internally has broke. It's been put off as most people we've talked to said you do not want to rebuild one, but after rebuilding this one, it isn't terrible bad...which means now I've got about 4 more to rebuild.
As for the sticker for the center, it did actually come that way.
Then about your jeep, does it have a coupler like the one I have a few posts above? If so what model of Jeep do you have, apparently that coupler is not GM but it links the steering column to the steering motor.
This one just has a drop off/raise for accessory.
the one above came in a new looking box.
This one has a small roll key/pin before accessory.
9217, and came in an older looking box.
Both boxes, in case someone is wondering.
For what it's worth, they were $20 cheaper than what Napa/Carquest/Hedahls/AutoValue/Advance/O'ReillO'Reilly's wanted for a new one.
https://www.jegs.com/i/Crown+Automot...8710K/10002/-1
also, Jim Shea x1000000! He eats, sleeps and breathes these columns
