Help Finding a Front Spoiler Extension
Old Jun 6, 2025 | 06:18 PM
7T1vette's Avatar
7T1vette
Do you feel that you NEED the extension on what you now have, or do you not have one, presently? IMO, anything which hangs down below where the stock air dam is positioned is likely going to be broken off, before long. Lots of folks have trouble keeping the stock air dam undamaged. Is your desire for this spoiler 'functional' or just 'cosmetic'?
Old Jun 7, 2025 | 12:26 AM
Primoz's Avatar
Primoz
2017 C3 of Year Finalist
Actually that is a good point. I see on my friends 80 Corvette that his lower air dam is all scuffed.
I have an aluminum radiator and the temperature never goes above of the thermostat specified temperature.
I do like the looks of the air dam, though.
Old Jun 7, 2025 | 06:17 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Those bigger air dams are a must for higher horsepower motors. Its mostly the drivers fault if they are broken either from parking or not enough angle of attack on a speed bump. Rock chips are par for the course from using the vehicle
And it being thick rubber it wont crack
Old Jun 7, 2025 | 12:05 PM
7T1vette's Avatar
7T1vette
I don't think the larger air dam is the issue, if the engine runs hot. Most likely, the radiator needs a clean-out or replacement with a larger aluminum unit. The amount of airflow provided by the stock air dam is plenty adequate, if the cooling system is "up to snuff".
Old Jun 7, 2025 | 12:12 PM
OldCarBum's Avatar
OldCarBum
For 73 they were actually a factory addition to the oem spoiler on ac optioned big block cars.
The factory added them to help scoop up more air from under the car at slow speed and also to create more negative air up behind the radiator at highway speeds so more air is pulled through the radiator.
I believe they were factory additions on 73-79 ac cars, then the 80-82’s had the new designed front end and the extension was no longer necessary.
Old Jun 7, 2025 | 12:33 PM
interpon's Avatar
interpon
Originally Posted by Primoz
Can you provide the thickness of the front air dam extension as I would like to make one myself as none are available any more.
if helpful here is a 79 post 13 addng an oem spoiler replacing the riveted extension. Thickness in there too. 19/100
https://www.corvetteforum.com/forums...on-advice.html
Old Jun 7, 2025 | 08:26 PM
OldCarBum's Avatar
OldCarBum
I happened to be home today and had enough time to pull down the box containing the spoiler extension from the garage shelf.
I took a quick caliper measurement of approximately .19” which is about as close as you can get to 3/16” or .1875” rubber.
Old Jun 8, 2025 | 03:37 AM
Primoz's Avatar
Primoz
Awesome! Thank you for all the effort and help!
Old Jun 8, 2025 | 12:52 PM
OldCarBum's Avatar
OldCarBum
Any time!
Old Dec 24, 2025 | 09:33 PM
J.Abbott's Avatar
J.Abbott
They are 3/16, just measured my NOS one I have had since the mid 80's.
