carb replacement question
Old Aug 8, 2023 | 08:17 PM
delandjohn's Avatar
delandjohn
Default carb replacement question
Need to replace the quadrajet on my 1972 454. (old one has been rebuilt twice and is just worn out). What are pros and cons of new vs. factory rebuilt?
Old Aug 8, 2023 | 08:53 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
send it someone who will restore and rebuild and not just throw a "kit" in it.
Old Aug 8, 2023 | 09:04 PM
Bikespace's Avatar
Bikespace
They don't make "new" quadrajets, and a factory rebuilt unit is likely to be assembled from a haphazard collection of incorrect parts.
Send it to @lars, or perhaps look for a rebuildable core to send him instead. I think a worn throttle shaft is fixable, but I'd post some photos and ask first.
Old Aug 8, 2023 | 11:56 PM
lars's Avatar
lars
You can't buy a new Q-Jet, and there are no "factory rebuilt" Q-Jets. (The "new" Chinese made Q-Jets are complete junk and will not run out of the box without major machining and rework operations). "Commercially rebuilt" Q-Jets are complete and total junk. The '72 454 Q-Jet is a very rare carb, and cannot be replaced. It needs to be repaired by someone who knows what they are doing at any cost. Your carb, if correct and original, is worth around $2K. There are no replacements. You're dealing with a rare antique a half century old. There are no new parts, and the "factory" isn't making, rebuilding, or servicing parts anymore. Pony up and pay what it takes to own an antique.
Old Aug 9, 2023 | 07:49 AM
delandjohn's Avatar
delandjohn
Thanks for the advice. I really appreciate it.
Old Aug 9, 2023 | 08:02 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Holley makes a spread bore Q-Jet replacement carb but they discontinued the 750cfm model......the 650 that is available will not have a fuel curve anywhere near what it is supposed to have for a 454ci engine.....it could be jetted to work, but that would need to be done by knowledgeable tech......well versed in carbs and tuning......
Send the carb to Lars above....he can and will restore it to factory spec.......nothing will run better on your 454.....
Jebby
Old Aug 9, 2023 | 04:09 PM
lars's Avatar
lars
See my posts and comments about big block carbs here:
https://www.corvetteforum.com/forums...t-salvage.html
Lars
Old Aug 9, 2023 | 07:03 PM
delandjohn's Avatar
delandjohn
Thanks. Will check it out.
Old Aug 9, 2023 | 07:46 PM
Mr D.'s Avatar
Mr D.
Contact Lars I'm sure he can inspect your carb and tell you if it is "just worn out".
Old Aug 9, 2023 | 08:46 PM
lars's Avatar
lars
All I need are some good photos of the carb and a carb number....
What's wrong with the carb? What's "worn out?" Is it not actually the correct carb..?
Lars
To carb replacement question
