Different heads on motor
Old Jan 3, 2024 | 03:33 PM
  #81
Bikespace's Avatar
Bikespace
Please excuse the dumb question: Are you certain the threads aren't too long on the spark plug, and hitting the top of the piston?
Old Jan 3, 2024 | 03:41 PM
  #82
HeadsU.P.'s Avatar
HeadsU.P.
Wow. What a great question. Wouldn't that be something! Better to know right now than when you hit the key to crank it.
Old Jan 3, 2024 | 04:20 PM
  #83
scondon's Avatar
scondon
Originally Posted by stingr69
Do the plug threads have helicoils from Edelbrock? I seem to remember getting them that way. It's been some time so it may have changed.
no they don’t, they have the washer on them
Old Jan 3, 2024 | 09:07 PM
  #84
OldCarBum's Avatar
OldCarBum
I think stingr69 is referring to the threads in the heads for the plugs.
Have you tried to remove the one plug?
Hopefully the thread on the plug is messed up and it stopped turning as soon as it engaged with the threads in the head.
Old Jan 3, 2024 | 09:11 PM
  #85
OldCarBum's Avatar
OldCarBum
As far as frames go, contact David Howard AllC34Me here on the forum.
He is the frame Guru and can probably give you some good advice and may have a frame he wants to get rid of.
Old Feb 1, 2024 | 07:46 PM
  #86
scondon's Avatar
scondon
Well the saga continues. Got the motor all back together. After trying tread chasers, and taps, no luck the plug still faces up from the other plugs. Contacted elderbrock and summit racing long story short had to tear the motor back apart to take the heads back to summit so they can look at them. In process radiator upper inlet hose broke so had to get a new radiator, new water pump,new fuel pump. I am going nuts. This was supposed to be a simple head swap. 😩
Old Feb 1, 2024 | 10:46 PM
  #87
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
David has no more frames, and I believe is taking a step back from all things Corvette all the time for a bit.
Old Feb 2, 2024 | 07:30 AM
  #88
scondon's Avatar
scondon
just got back from saint louis mo picking up a frame that was in great shape. No rust and it was straight. So frame issue is solved
