C3 Bumper Identification
Old Feb 18, 2024 | 11:30 AM
Cybersnypa's Avatar
Cybersnypa
Default C3 Bumper Identification
Hello, I have this nice fiberglass bumper for a c3 corvette BUT it doesn't fit my 75. I know it has the tail from an 82 but they make 82 style bumpers that fit a 75. I want to confirm that this actually fits an 82. My question is the curve on the back of the 82 deeper than a 75? Because that's the main reason why this bumper doesn't fit. It wont sit flat against the back deck. Thank you for the help.
Old Feb 19, 2024 | 01:20 PM
MelWff's Avatar
MelWff
This company uses the same fiber glass bumper for 74 to 82
https://www.acivette.com/
Old Feb 19, 2024 | 02:18 PM
Cybersnypa's Avatar
Cybersnypa
That what I found too. It says there all the same. But this bumper doesn't fit at all. And side note, a 75 bumper doesn't fit a 74.
This is the gap on the back of my 75. It wont bend and its hitting the bumper. What the heck bumper does this car go to?
Old Feb 19, 2024 | 05:16 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
75 doesn't have the spoiler.
pic looks 80ish
Old Feb 19, 2024 | 05:38 PM
MelWff's Avatar
MelWff
pic looks 80ish
He knows that. The question is are 80 to 82 rear body upper panels different to account for the gap between bumper and body or is this a defective bumper.
Old Feb 19, 2024 | 05:39 PM
Cybersnypa's Avatar
Cybersnypa
pic looks 80ish
Yeah but when you shop online, the websites say all the bumpers fit 75-82. How is that possible when an aftermarket bumper like this doesn't fit. They also say 75 bumpers will fit a 74 and they absolutely will not.
My main question is does an 82 have a deeper curve at the back?
Old Feb 19, 2024 | 05:40 PM
Cybersnypa's Avatar
Cybersnypa
Old Feb 19, 2024 | 06:00 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
yes, different years have different shapes.
an 80 to 82 will not direct bolt to 75
Old Feb 19, 2024 | 06:06 PM
Cybersnypa's Avatar
Cybersnypa
Ok thats what I am looking for. Seeing as how this bumper has a different curve. Any idea what this bumper will actually fit?
Old Feb 19, 2024 | 06:07 PM
calwldlife's Avatar
calwldlife
St. Jude Donor '22
looks 80-82 as said
Old Feb 19, 2024 | 06:25 PM
Bikespace's Avatar
Bikespace
That's not a stock 80-82, either. That's the nifty tall spoiler that came on my 79. Possible sources are documented on this thread. All fiberglass bumpers require some fitting. Some more than others.
Does it say anywhere who cast it? There seem to be several sources.
https://www.corvetteforum.com/forums...-pictures.html
https://www.corvetteforum.com/forums...ar-bumper.html
Old Feb 19, 2024 | 06:29 PM
Cybersnypa's Avatar
Cybersnypa
There is no manufacturer labels.
Old Feb 19, 2024 | 06:50 PM
F4Gary's Avatar
F4Gary
2018 C3 of Year Finalist
2016 C3 of the Year Finalist
Go here to post #7 and PM that guy (Mod75).
https://www.corvetteforum.com/forums...per-cover.html
Old Feb 19, 2024 | 07:08 PM
Cybersnypa's Avatar
Cybersnypa
Thanks, I would like to ask if someone with a 80-82 corvette would draw a string across the tail of there car and see how many inches there curve is. Then I will compare it to mine.
Old Feb 19, 2024 | 07:48 PM
Bikespace's Avatar
Bikespace
Easy!
On my 80, there was a 15/16" offset from straight at the center. On my 79, there was a 7/8" offset from straight at the center. Note that the 79 actually has that exact bumper already installed (or one just like it), so it may have been shaved a bit when the car was first restored 20 years ago.
I'll post photos when my phone finishes downloading them. If there is a difference between my cars and yours, I'd expect the change to have occured between 77 and 78, when the rear switched from sugar scoop to bubble window.
Old Feb 19, 2024 | 07:57 PM
Bikespace's Avatar
Bikespace
The white car is my 80, black is my 79.
Old Feb 20, 2024 | 12:01 AM
Cybersnypa's Avatar
Cybersnypa
@Bikespace Thank you SO much. I will check on this tomorrow.
To C3 Bumper Identification
Old Feb 20, 2024 | 06:34 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
You realise that's just a tiny bit of difference don't you?
you are also aware if you messured 20 1979 cars none would be precisely the same don't you?
you can clearly see that sanding down the inside of that bumper cover on the outer sides will get it to fit, right?
you are aware that any replacement bumper will need fitting on these cars, right??
Old Feb 20, 2024 | 07:23 AM
Bikespace's Avatar
Bikespace
I bet it would take less time to measure your 77 than to speculate.
I don't think there's a difference either, but if there is, your car would show it.
Old Feb 23, 2024 | 03:47 PM
Scooby69's Avatar
Scooby69
I understand that fiberglass bumpers need SOME work to make them fit, but from what I see in the picture, the fitment is nowhere close...
