Replace Rag Joint?
Old Mar 22, 2025 | 05:08 PM
aznd's Avatar
aznd
Default Replace Rag Joint?
Pulled the steering column out. Thoughts on replacing the rag joint while I'm at it? It doesn't look as worn out as some other people have posted theirs, but might as well replace while I'm at it?
Old Mar 22, 2025 | 05:53 PM
GTR1999's Avatar
GTR1999
It has an "S" bend it in. That can possibly be from a compressed column. Remove it for a good inspection. The box probably needs work too.
If you replace it, what do you think you're going to get? No one makes a rag like Saginaw or Tom Reina made today. Most are Chinese, some with the D-Flat 180* off. A NOS one is the best and they $300+ if you can find one. One place on Ebay is selling what they call NOS but they're not the same and most likely made by the company that bought out Saginaw. A U-Joint will work as well.
Old Mar 22, 2025 | 06:16 PM
aznd's Avatar
aznd
@GTR1999 Thanks for the response. Makes sense to replace the rag joint.
Would this replacement from Top Flight work? Didn't realize that drop-in replacements were so hard to find.
https://www.topflightautomotive.com/products/1967-1982-chevrolet-corvette-borgeson-rag-joint-18mm-dd-x-1-48-borgeson-universal/
Old Mar 22, 2025 | 06:37 PM
GTR1999's Avatar
GTR1999
Your rag joint may be still good, and if it is, it would be what I use.
Old Mar 23, 2025 | 11:21 PM
7T1vette's Avatar
7T1vette
Me too. If the webbing isn't damaged or torn, clean it up and reinstall it. Aftermarket stuff is JUNK.
To Replace Rag Joint?
