1971 LT-1 engine
Old Oct 25, 2025 | 04:29 PM
aa468blown's Avatar
aa468blown
Default 1971 LT-1 engine
Anyone have an idea what a complete 1971 LT-1 engine is worth? everything except the carb. Needs a rebuild
Old Oct 25, 2025 | 05:08 PM
Alan 71's Avatar
Alan 71
Hello,
What the stamp pad looks like and how complete the engine is (the parts that made it a LT!) might have an impact on it's value.
Regards.......
Old Oct 25, 2025 | 05:45 PM
Rebelyell's Avatar
Rebelyell
It will have meaningful value Only to someone who Needs a year-specific gen I LT1.
To most others, it's just another worn out 350 w/ a 2-piece rear main seal, forged, mild steel crank. At best, 71 LT1 heads are ho-hum.
Old Oct 25, 2025 | 05:48 PM
aa468blown's Avatar
aa468blown
The engine is 100% complete minus the carb, the suffix is CGZ
Old Oct 25, 2025 | 06:00 PM
aa468blown's Avatar
aa468blown
Agreed, but i wouldn't be counting on selling the engine to anyone other than someone that has a 71 LT-1 missing the engine. They only made 1949 1971 LT-1s, if someone has a documented car but they are missing the engine, i would think even knowing the VIN number is different it should have substantial value. Very rare 71/72 valve covers, one year intake and cylinder heads and Transistorized ignition. Those parts aren't just laying around these days. The cars are going between 50k to 100k, Being the LT-1 engine is the key to an LT-1 car i would think it has pretty good value. My thoughts are $3500 complete with intake and distributor. I know the distributors alone can go for $1000 and the intake $500, I would think the valve covers are worth $500 also. But i wanted to hear from others that know the value of 71 LT-1 parts.
Old Oct 25, 2025 | 07:13 PM
Piersonpie's Avatar
Piersonpie
Here’s one from 2015 selling for $1500. Add a decade of inflation I think your price is fair.
Old Oct 25, 2025 | 08:11 PM
litevette's Avatar
litevette
I replied in your same question post you put into the LT-1 owners thread. I am with you on the parts values maybe being the way to sell it, unless you can find the guy that is missing that specific motor.
Old Oct 26, 2025 | 01:55 PM
firstgenaddict's Avatar
firstgenaddict
The TI distributor, correct water pump, intake, and valve covers are worth a good bit. Does it have the correct fuel pump on the engine?
Old Oct 26, 2025 | 02:20 PM
aa468blown's Avatar
aa468blown
not sure about the fuel pump, i will check.
Old Oct 30, 2025 | 12:36 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
$3500 with TI distributor and carb....
$2000 without....
Jebby
Old Oct 30, 2025 | 11:51 AM
firstgenaddict
Water pump and fuel pump are worth a couple hundred each as cores.
To 1971 LT-1 engine
