Shaking
Old Dec 2, 2025 | 08:20 AM
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
When you solve this please post the answer here. Some folks start a new thread which, is sometimes difficult for the rest of us to find the answer.
Good luck
Old Dec 3, 2025 | 12:33 AM
Rebelyell's Avatar
Rebelyell
Perhaps there are more issues than only one ? And perhaps they are Not related Nor interdependent ?
Old Dec 15, 2025 | 06:01 AM
ALLEN007's Avatar
ALLEN007
I still haven't done anything on this due to Christmas and busy. A couple of you mentioned it could be wheel bearings. A friend of mine told me the same thing and said to check it jack the car up a bit, put a crow bar or 2 x 4 under each tire and lift up. If it moves the bearings are going.
I did this yesterday and the results are, Front right: did not move, Front left: move about 1/8", Rear right: moved about 1/8", Rear left: moved at least 1" or more.
What ya think?
Thanks.
Old Dec 15, 2025 | 07:51 AM
Piersonpie's Avatar
Piersonpie
If you don’t know the last time they’ve been done I would do them regardless. It’s cheap and easy enough (the fronts at least,) and getting that deep into the suspension might reveal what the issue is even if it’s not the bearings.
Old Dec 15, 2025 | 08:02 AM
biackbenz's Avatar
biackbenz
I have a thread going on - Trailing arm or differential. 1978 with at least 110k miles. Car became undrivable. I lifted the rear wheels and did not see any movement . Once I disconnected the struts and shock and half shafts there was a lot of movement. I must not have given it enough push / pull.
left wheel bearing shot. Differential yokes move in and out a lot. Trailing arm bushings shot. They are in for rebuild.
Old Dec 15, 2025 | 08:14 AM
Bikespace's Avatar
Bikespace
Can you post a video showing the movement?
Are you sure it's in the bearing, and not the strut rod, or the the axle stub in the differential?
Old Dec 15, 2025 | 08:45 AM
biackbenz's Avatar
biackbenz
yes. The rotor moves all directions and the TA is not. Rebuilder has started that one a bearing, race and spindle are being replaced. Sorry didn’t take a video.
Old Dec 15, 2025 | 10:35 AM
Rescue Rogers
Anything that moves one inch when it shouldnt is bad. If one is going they are all suspect. They all have the small mileage
