It's alive!!
Old Feb 3, 2005 | 09:47 PM
Bangkok Dean's Avatar
Bangkok Dean
Originally Posted by burners
That's great news, congrats. Don't be causing any earthquakes with that new engine.
Yes here in Thailand everyone is watching the beaches now.
Old Feb 3, 2005 | 09:56 PM
GDaina's Avatar
GDaina
Congrats on a job well done
Old Feb 3, 2005 | 10:07 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by isosceles
way to go OLIVIER!!!
good job
Did it scare ya a little when it fired?
Not scared, but surprised that it fired up immediately...
luerja's Avatar
luerja
It is great to win a battle once in a while.......
Good Job,
A little kicker along the way to getting the car on the road keeps you motivated.
Jim
GrandSportC3
Originally Posted by Redshark6974
told ya it would fall in...congrats!
Didn't really "fall" in.. I had to force it in by twisting and pushing...
Old Feb 3, 2005 | 10:09 PM
GrandSportC3
I'm proud that I got everything done by myself.. Mr. Wonderful (Alan) helped me on the day that I attached the transmission to the engine, but other than that, I did everything myself...
It's a good feeling
Old Feb 3, 2005 | 10:10 PM
GrandSportC3
Good Job,
Jim
Still have to find a way to remove the pinion yoke.. Tried it tonight but the bolt that holds it is very tight...
FeedVaal's Avatar
FeedVaal
I'd be scared somethingless to drive that car if the differential is suspect. Better to just listen to it go vroom-vroom in neutral for awhile until you get that sorted out.
Old Feb 3, 2005 | 10:13 PM
GrandSportC3
I won't drive more than 5 to 10 miles once I get the driveshaft in.. Want to see how the transmission shifts and check for any leaks that I'll have to address... I had a few leaks on the fuel system which I all fixed. When I initially ran the fuel pump for the first time, fuel would just sqirt all over the place
Fixed all the issues and I don't seem to leak fuel anymore... There seems to be a small leak somewhere on the tranny lines.. There was some tranny fluid under the car after firing it will try to find the issue tomorrow...
Old Feb 3, 2005 | 10:15 PM
GrandSportC3
I have experiences driving with damaged differentials.. I actually drove once over 300 miles with a differential on which each spider gear had a tooth missing and the posi case was cracked
I won't have that differential fixed because my 12-bolt IRS setup is going in in a couple of weeks...
Old Feb 3, 2005 | 10:22 PM
Torch Red's Avatar
Torch Red
St. Jude Donor '09
How about some audio video of it ... no WMV though.
Old Feb 3, 2005 | 10:26 PM
GrandSportC3
I'll make a video tomorrow.. However - I have no place to host anything but .wmv videos.. If somebody has webspace that allows mpegs to be hosted I'd be more than happy to post a mpeg video!
Old Feb 3, 2005 | 11:18 PM
  #33
Daytona69's Avatar
Daytona69
Very, very
Congrats!!!
Old Feb 3, 2005 | 11:24 PM
  #34
outrunm's Avatar
outrunm
St. Jude Donor '06
Originally Posted by GrandSportC3
Forgot to mention.. The engine really sounds like a real race car engine
It sounded like that 3 months ago!
Old Feb 3, 2005 | 11:32 PM
  #35
GrandSportC3
The old engine sounded nothing like the new one.. The cam on the new engine 30 degrees more .050 duration and is a solid roller... A solid roller just sounds completely different
Old Feb 3, 2005 | 11:49 PM
  #36
Bob Turner's Avatar
Bob Turner
Originally Posted by Jughead
Probably won't get much sleep tonight.
HAHAHAAHAHAHAHAHAHAHAHAHAHA!!!
Bob
Old Feb 4, 2005 | 12:50 AM
  #37
comp's Avatar
comp
you WIN
To It's alive!!
Old Feb 4, 2005 | 01:08 AM
  #38
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Cool!!! Congratulations.....looking forward to seeing/hearing it at the Cruise In!!
JIM
Old Feb 4, 2005 | 02:48 AM
  #39
GDaina's Avatar
GDaina
use an impact wrench on the pinion nut.....if it won't budge, heat on the nut
Old Feb 4, 2005 | 04:28 AM
  #40
Aflac's Avatar
Aflac
Cruise-In 5, 6 & 10 Veteran
St. Jude Donor '09
YA!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! great job Oliver! something tells me you are gonna be the alarm clock at CI again, aren't ya? I kid you not, the last engine was angry enough! If this one is worse, Lord help us!
