It's alive!!
Old Feb 3, 2005 | 08:47 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default It's alive!!
Finally got the distributor in! I had to twist the housing to get it in...
The engine fired on the first turn of the ignition key.. I let it run for 10 seconds and shut it down.. It was too late in the evening and I didn't want the neighbors to call the cops on me.. The idle was also pretty high....
I'll set the timing tomorrow and adjust the idle... I hope to get the driveshaft in too so that I can take her for a spin... I won't go too far because the differential is shot and occasionaly locks up
Old Feb 3, 2005 | 08:48 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Probably won't get much sleep tonight.
Old Feb 3, 2005 | 08:49 PM
GrandSportC3
Forgot to mention.. The engine really sounds like a real race car engine
Old Feb 3, 2005 | 08:56 PM
Glassbowtie77's Avatar
Glassbowtie77
Old Feb 3, 2005 | 09:02 PM
trevkris2's Avatar
trevkris2
Old Feb 3, 2005 | 09:04 PM
kdf1986's Avatar
kdf1986
Glad to read that you finally got it fixed. What was the problem with the distributor that it would not drop all the way in. You wrote that you had to twist the housing, is that the main barrel/shaft of the distributor?
kdf
Old Feb 3, 2005 | 09:06 PM
LFZ's Avatar
LFZ
told ya it would fall in...congrats!
Old Feb 3, 2005 | 09:11 PM
69 N.O.X. RATT's Avatar
69 N.O.X. RATT
From: Pettis Performance 565 with two stages of Nitrous Supply nitrous 1.082, 4.61 at 155, 7.17 at 192
Congrats
Old Feb 3, 2005 | 09:13 PM
shoptek's Avatar
shoptek
Got wood ?
EDDIEJ82's Avatar
EDDIEJ82
Old Feb 3, 2005 | 09:17 PM
88'Cubka's Avatar
88'Cubka
St. Jude Donor '08
That's what you built. lol
GrandSportC3
Kdf, yes, I twisted the barrell/shaft... Oil pressure built up immediately when I fired up the engine, so I know that the distributor is in right!
I also got it perfectly pointing to #1
Old Feb 3, 2005 | 09:24 PM
gr8whte's Avatar
gr8whte
St. Jude Donor '05-'06-'07-'08
Originally Posted by shoptek
Got wood ?
im sproutin a louiville slugger ovah heea
comp's Avatar
comp
ALL Right
Old Feb 3, 2005 | 09:28 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Old Feb 3, 2005 | 09:30 PM
CrossedFlags77's Avatar
CrossedFlags77
Congrats!
Old Feb 3, 2005 | 09:33 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Good stuff, always fun starting it up te first time.
To It's alive!!
Old Feb 3, 2005 | 09:39 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
vroom vroom!!
Old Feb 3, 2005 | 09:42 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
That's great news, congrats. Don't be causing any earthquakes with that new engine.
Old Feb 3, 2005 | 09:45 PM
isosceles's Avatar
isosceles
way to go OLIVIER!!!
good job
Did it scare ya a little when it fired?
