What the C3 REALLY needs
Old Jul 24, 2005 | 09:30 AM
  #241
KenSny's Avatar
KenSny
DEP: I did read all the posts at least until I got the feeling you are just wading in for the now.
Anyway, thank you very much for pointing out that you are becoming more and more paranoid as time goes by. You start a thread knowing that it will cause most here to "rant" one way or the other, then you feel like we are picking on you. You used to be a fun guy but now.......... into my ignore list. BTW: It won't hurt my feelings at all if you do the same. Rest in peace.
Old Jul 24, 2005 | 09:53 AM
  #242
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Yep...I find it interesting that upon your return the first thing you do is make a point to attack me on every thread I post to. Welcome to MY ignore list
Dep
Old Jul 24, 2005 | 10:24 AM
  #243
Techno's Avatar
Techno
Do you need a suspension for drag racing?
If a solid axle is so great for straight line couldn't the suspension just be eliminated? Lock in a solid axle and most of this conversion is gone.
Old Jul 24, 2005 | 10:47 AM
  #244
Glensgages's Avatar
Glensgages
I think the 'suspension', and the 'solid-axle' are two different things in this case:
while the suspension isn't the best for drag-racing, the C3's rear-end, from the carrier out-board to the wheel, has many 'moving-pieces', prone to breakage, that don't help in a straight-line / acceleration-contest.
Many late 2nd-generation Camaros and Firebirds run well into the 11's (and even quicker) with the fairly-standard 8.5" ring-gear 10-bolt rear-end with little-to-no problems or breakage:
if it was easily-possible to mount a complete 10-bolt housing with leaf-springs, I'd think most C3 drag-racers would go this route, but since it isn't feasible, narrowing the frame-rails, and installing a much-stronger 9" Ford housing (which also makes gear-changes easier) with wheel-tubs and a coil-over/4-link suspension is what most often happens.
Old Jul 24, 2005 | 11:22 AM
  #245
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Originally Posted by KenSny
Come on DEP stop stirring the fire again.
You know as well as most of us that the Corvette was designed to be Duntov's child on the road race circuit. Not a drag strip, not a circle track, not a dirt track, not auto cross, etc. Now here you come saying you don't like the way it was designed, and 30+ years too late at that!
Solution: Redesign the car from the ground up. :
That's not a good argument for IRS at all. Duntov designed the car to sell and make GM money. The Corvettes primary intention may have been based on road racing but the suspension was never anything special even in the early years. Then it was not updated or even maintained well from 1963 -1982 when the factory did indulge in some sponsored road racing.Gulstrand did what he could with the IRS and there was very little he didn't replace. It still had an early 50's design until the C-4 came out. So I can't see any great direction on handling by GM for almost 20 years. Ask TT , Norval and Redvetracer or several others here to see how bad the C-3 suspension really is. If it were that great we wouldn't be trying to re-design the IRS for handling and it is for sure not built to drag race.
As for drag racing, the Corvette body is a great one for any racing event. The problem is that the IRS is not bullet proof and as horsepower and suspension have evolved the Corvette now has need of a solid axel suspension to be competitive in drag racing. I can't see the big deal of going to a solid axel in a C3. There is nothing sacrilegious about it. If someone decides to use a Corvette for drag racing so what? To me it is no different changing a Vette to solid axel than changing from leaf springs on a Camaro to a four link with coil overs.
Nascar is another area of racing that uses a body to represent a vehicle that under the skin has no actual parts of the original car at all. Front wheel drive Monte Carlos were never laughed at when Dale Earnhardt drove them even though they were no longer front wheel drive.
I can't see any argument to say that all Corvettes should stay IRS.
Alston Chassis Eng. will tell you the best way to do it Dep. Just don't tell them you are putting in a little 302, they might put on training wheels instead of wheelie bars.
Old Jul 24, 2005 | 03:21 PM
  #246
Techno's Avatar
Techno
Because the differential is mounted to the frame.
Stick a solid axle in there, mounted to the frame and unsprung. No suspension.
I don't know if a suspension is needed on a drag car thats why I ask this.
Old Jul 24, 2005 | 03:58 PM
  #247
norvalwilhelm's Avatar
norvalwilhelm
If someone like Twin Turbo told me my car would handle better with a solid axle I would do one this winter. I really don't see the big deal. I just thought for hard street running the independent rearend handled better.
To me it is all about handling .
Old Jul 24, 2005 | 04:18 PM
  #248
Twin_Turbo's Avatar
Twin_Turbo
The true benefit of the solid axle over the IRs in case of drag racing is the anti squat that you can set it up with because the differential is part of the suspension unlike the IRS where you can get maybe 20-25% of anti squat, on a solid axle it's possible to get 100% anti squat and therefore transfer all power directly to forward propulsion instead of wasting it in the suspension.
Old Jul 24, 2005 | 04:31 PM
  #249
DJ Dep's Avatar
DJ Dep
Plus only 2 u-joints to worry about instead of SIX. Plus much beefier ring and pinion gears than what the Vette comes with. Plus aftermarket parts that make it even MORE heavy duty.
Old Jul 24, 2005 | 11:19 PM
  #250
Glensgages's Avatar
Glensgages
The only un-sprung drag-cars are dragsters, who's chassis have slip-joints on the vertical bars, allowing the upper and lower frame rails to 'flex', keeping the front tires on the ground, while transferring weight to the rear tires.
Old Jul 25, 2005 | 10:23 AM
  #251
TPIShark's Avatar
TPIShark
I might be over-simplifying things, but would seem to me that an f-body-type rear, where the control arms would attach to where the trailing arms are, and the coils perch where the exisiting x-member is, could maybe be fabricated.....
Old Jul 25, 2005 | 10:35 PM
  #252
JoeC427's Avatar
JoeC427
Old Jul 26, 2005 | 04:03 PM
  #253
Quick 1's Avatar
Quick 1
I just cant say it any better myself!
Old Jul 26, 2005 | 04:11 PM
  #254
Quick 1's Avatar
Quick 1
how hard r u running on the street? if u can go fast around corners and still see around that very nice motor than you must have a co-pilot because i cant do right turns as fast as left turns! If you rode in my vette the only time you know when i have a solid rear is when i bang all 4 gears hard and all my stuf is still intact when I slow down! Just do it !
Old Jul 26, 2005 | 04:22 PM
  #255
norvalwilhelm
I often cruise in the 100mph range and yes right corners are harder but after 4 years of driving this combination you get a system that works. I often take corners at 3 times the recommended speed. The worst part for me about installing a ford 9 inch is the 26 inch driveshaft. Right now the driveshaft angles are almost straight, within a degree anyway.
What happens with the ford 9 inch is the short short driveshaft goes through a big big change if you have a suspension that actually works. Spring it hard enough and that is not a concern. To me I like running soft springs and actually have the wheels go up and down. This puts a big load on the universals.
Before anyone says What about the 1/2 shafts?? They are running at about 1/3 the speed of the driveshaft.
The installation is not a problem, weather is is actually better from the handling point is...
Old Jul 26, 2005 | 04:48 PM
  #256
norvalwilhelm
I would like to see you do a post on installing the rearend. Did you cut the battey boxes, modify them in any way?
Are you running 2 leaf springs? coilovers? ladder bars?
Do a post on this giving as many pictures as possible.
How about high speed vibration with the short driveshaft.
Start a new post on this.
Old Jul 26, 2005 | 05:49 PM
  #257
EDDIEJ82's Avatar
EDDIEJ82
I agree with Norvals idea
A post about how to go about this, what parts of the frame has to be cut, moving things like battery box and gas tank, how it handles afterward, what to look out for when doing this swap from someone that's already done it, what size/width tires would fit afterwards, would be PRICELESS on this forum... as this topic comes up every month.
To What the C3 REALLY needs
Old Jul 26, 2005 | 06:25 PM
  #258
MakoVai's Avatar
MakoVai
Cruising
You mean vettes can go round corners too?
Old Jul 26, 2005 | 06:35 PM
  #259
big632's Avatar
big632
Looks like a little too much tire for the vette body.framerails too wide.
Old Jul 26, 2005 | 06:53 PM
  #260
rcread's Avatar
rcread
Looks like everything fits in the picture in the profile.
