Tuned port injection help
Old Mar 29, 2005 | 06:02 PM
  #41
Fireslayer26's Avatar
Fireslayer26
Pat, you wouldnt happen to have a diagram on how all those ports are hooked up would you? Also, what is the stock fuel regulator on the TPI setup set at?
Old Mar 29, 2005 | 06:29 PM
  #42
PatsLs1vette's Avatar
PatsLs1vette
Better yet ill take pics of what ever you need and send them to you.And my fuel pressure is at 42lbs stock.But ive seen anywhere from 39-43 on a few camaros and trans ams and vettes ive worked on.
Old Mar 29, 2005 | 06:45 PM
  #43
Fireslayer26
That would be awesome pat! If you could take pics showing where the hoses for those ports run to and from. Also which ones you have blocked off. Oh and if you have time, maybe some pics on where you routed all the wiring.
Thanks a million!!
Old Mar 29, 2005 | 06:50 PM
  #44
PatsLs1vette
Can you wait till tomorrow night?Im watching the baby tonight
Old Mar 29, 2005 | 07:05 PM
  #45
Fireslayer26
No problemo pat!
...Oh, could you also include some pics showing how you got the distributor and MSD 6A box setup?
Old Mar 30, 2005 | 06:53 PM
  #46
Fireslayer26
Would you happen to know, what size injectors came with my setup? Should I get larger ones?
Old Mar 30, 2005 | 07:03 PM
  #47
PatsLs1vette
If its a 305 it came with 19 lb if it is a 350 then 22lb.im getting pictures together now.I also have an external fuel pump im selling in the c3 section.also email me your email address so i can send them
pats73vette@comcast.net
Old Mar 30, 2005 | 08:25 PM
  #48
Fireslayer26
I emailed you pat. Plus I may be interested in your fuel pump. Whats the PSI and flow rate of it?
Old Mar 31, 2005 | 07:21 PM
  #49
Fireslayer26
Is this the type of ESC I would need for my setup? Would I still need this if I had a MSD 6A ignition?
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
Old Mar 31, 2005 | 07:53 PM
  #50
PatsLs1vette
yes thats the one,did u get my email ?
Old Apr 1, 2005 | 02:01 PM
  #51
Fireslayer26
Yes, I got it, thank you.
Old Apr 4, 2005 | 05:44 PM
  #52
Fireslayer26
Hey pat, could you give me schematics on how you integrated the MSD 6A box into your system?
Old Apr 4, 2005 | 07:47 PM
  #53
PatsLs1vette
in 1 hour i can, wife will be home to watch kid,geez this fatherhood stuff is tough lol.
Old Apr 4, 2005 | 08:59 PM
  #54
PatsLs1vette
check your instant messages.
Old Apr 4, 2005 | 11:01 PM
  #55
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
Check out S & P 's site, you can download the install instructions to the tpi system.
Old Apr 7, 2005 | 03:23 PM
  #56
Fireslayer26
Sorry, S & P?
Old Apr 7, 2005 | 04:46 PM
  #57
thebruce's Avatar
thebruce
S&P is Street and Performance. They sell a lot of TPI conversion related gear. http://www.hotrodlane.cc
To Tuned port injection help
Old Apr 7, 2005 | 09:59 PM
  #58
Fireslayer26
Thanks thebruce, I'll check it out! And does anyone know if this sensor would work with my setup?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6755
Old Apr 8, 2005 | 02:47 PM
  #59
thebruce's Avatar
thebruce
From what I've gathered on thirdgen.org and elsewhere, you need to get a knock sensor from the appropriate induction type, ie. get one from an 85-89 setup if you're running MAF, from a speed density year if you're running SD. Based on that, I'd guess that the knock sensor you pictured won't work.
Old Apr 8, 2005 | 04:24 PM
  #60
Fireslayer26
Ok, thanks thebruce. I'll see if I can find one for a 85-89.
