Accelerator Cable Question
Old Apr 1, 2005 | 01:48 AM
EVIL_GRIM's Avatar
EVIL_GRIM
Default Accelerator Cable Question
i was thinking about replacing the lower cable on my 79 with Cruise, now when i take the lower portion that connects tot he transmission, will fluid from the tranny start to leak out , and are there any o-rings that i will have to mess with? and what about the upper one? i know it goes through the firewall, is there a special grommet i need when i go to replace that one?
Old Apr 1, 2005 | 07:43 AM
markdtn's Avatar
markdtn
Fluid should not leak out, if it does either the "bullet" is worn out or the driven gear is.
The firewall gromment is a bit hard to install. If you can get your old cable out and the new one in without taking the grommet out it might be easier.
